This question seems slightly naive. The Hilbert pace of any 2-level quantum system is given by the Bloch sphere and the algebra of observables arises from $SU(2)$, the Lie group generated by the three Pauli matrices $\sigma_x,\sigma_y,\sigma_z$.
When considering spin chains, relevant for example in the NISQ quantum devicesand for algrithms such as the VQAs, the corresponding state space as far as I understand is $\mathcal{H}_{m} = SU(2) \times \ldots \times SU(2)$, that is for a length $N$ spin chain, $N$ copies of $SU(2)$.
If my understanding is correct, I struggle to see why many people claim that a $N$ qubit system's Hilbert space is described by $SU(2^N)$. Naturally, this is quite differnt to $\mathcal{H}_N$ described before, not only as a manifold, but also in terms of its generators which are definitely not matching the dimensions of a 2-level system for $N>1$.
For example, in this talk by a very senior researcher (at 0:11:00).
Therefore my questions boils down to:
  1. Is there some map between $f: \times_N SU(2) \to SU(2^N)$ for $N>1$?
  2. If not, isn't the claim that the Hilbert space of $N$ qubits is $SU(2^N)$ false?
Marion
  • 695
  • 14
Just a small remark for part of the question: Letting two Hilbert spaces $\mathcal{H}_1$ and $\mathcal{H}_2$ (this can be generalized to any linear space) the tensor product $\mathcal{H}_1 \otimes \mathcal{H}_2$ is again a space. The dimension is the product $\dim(\mathcal{H}_1 \otimes \mathcal{H}_2) = \dim(\mathcal{H}_1)\dim(\mathcal{H}_2)$ and this becomes general for arbitrary tensor of spaces. So, for instance, we get that $\dim(\mathcal{H}_N) = \dim(\mathcal{H_{qubit}}^{\otimes N}) = \dim(\mathcal{H}_{qubit})^N$.
So, the claim that Hilbert space of $N$ qubits is $\mathcal{H_{qubit}}^{\otimes N}$ is true in the standard formalism. But I think that there is a distinction between Hilbert spaces and Lie Groups to be made as well, and I shall leave someone else that is an expert to do so.
R.W
  • 2,468
  • 25
First off, the Bloch sphere is the complex projective line $\mathbb{C}P^1$, which is homeomorphic to $S^2$, while $SU(2)$ is homeomorphic to $S^3$. $SU(2^N)$ is the group of operators on pure states, not the state space itself.
The state space of an $N$-qubit system is complex projective space, $\mathbb{C}P^{2^N - 1}$; the elements of this space are equivalence classes of vectors. To see this, let's start with a single qubit, which can be represented by a vector $(z, w) \in \mathbb{C}^2$; since the magnitude of this vector is normalized to 1, the space is actually $\mathbb{C}P^1$ rather than $\mathbb{C}^2$. Multiple qubits are represented by tensor products of single qubit spaces, which we first take to be arbitrary vectors: $$ \mathbb{C}^2 \otimes \mathbb{C}^2 \otimes \cdots \otimes \mathbb{C}^2 (N \text{ times}) \cong \mathbb{C}^{2^N} $$ Normalizing the elements, we end up with $\mathbb{C}P^{2^N - 1}$.
Cody Wang
  • 1,293
  • 13
Just a small note because I've seen this confusion quite a bit, a qubit Does not form a Hilbert space. This is an oversimplification. What it actually forms is a (Projective Hilbert Space)
The details are well explained in this video. This becomes evident when analyzing a qubit state as a vector space (while all Hilbert Spaces need to be). Due to the normalization rule, none of our elements can be greater than 1. This means our set is bounded, which blocks it from being a vector space (which needs to have additive closure).
