I tried to change a little the code here for running the quantum volume circuits in real devices. My code is
backend = provider.get_backend('ibmq_bogota')
shots = 1000
for trial in range(ntrials):
clear_output(wait=True)
t_qcs = transpile(qv_circs[trial], backend=backend, initial_layout=qubit_lists[0])
qobj = [assemble(t_qcs)]
job_manager = IBMQJobManager()
job_set_foo = job_manager.run(qobj, backend=backend, shots=shots, name='QV trial %d'%(trial))
print(job_set_foo.report(detailed=True))
print(f'Completed trial {trial+1}/{ntrials}')
But I get
status: job submit failed: 'bad input to assemble() function; must be either circuits or schedules'
I don't understand how this can fail,since qv_circs must contain the necessary attributes. Note that I wrote qobj = [assemble(t_qcs)] instead of qobj = assemble(t_qcs). If I do the latter I obtain
'QasmQobj' object is not iterable
EDIT:
Some information about the objects:
print(t_qcs)
[<qiskit.circuit.quantumcircuit.QuantumCircuit object at 0x7fa2398698a0>]
print(type(t_qcs))
<class 'list'>
