I am trying to run a Qiskit QAOA algorithm on AWS Rigetti Aspen M 1 Backend using qiskit braket provider. However qiskit is not able to properly transpile the circuit
optimizer = COBYLA(maxiter=50)
provider = AWSBraketProvider()
backend = QuantumInstance(
    provider.get_backend("Aspen-M-1"),
    shots=1024,
    seed_transpiler=algorithm_globals.random_seed,
    seed_simulator=algorithm_globals.random_seed,
qaoa = QAOA(
    reps=p,
    expectation=cvar_exp,
    optimizer=optimizer,
    quantum_instance=backend,
    callback=store_intermediate_result,
ckt=qaoa.construct_circuit([1.0,1.5],qubit_op)
ckt[0].draw()
transpiled_circuit = transpile(
    ckt[0],
    backend=provider.get_backend("Aspen-M-1"),
    #seed_transpiler=42
transpiled_circuit.draw(idle_wires=False, fold=-1)
leads to the following error:
This backend's operations: h,id,p,rx,ry,rz,s,sdg,t,tdg,x,y,z only apply to a subset of qubits. Using this property to get 'basis_gates' for the transpiler may potentially create invalid output
AttributeError                            Traceback (most recent call last)
<ipython-input-117-94170a3bccca> in <module>
     40 transpiled_circuit = transpile(
     41     ckt[0],
---> 42     backend=provider.get_backend("Aspen-M-1"),
     43     #seed_transpiler=42
     44 )
~/anaconda3/envs/Braket/lib/python3.7/site-packages/qiskit/compiler/transpiler.py in transpile(circuits, backend, basis_gates, inst_map, coupling_map, backend_properties, initial_layout, layout_method, routing_method, translation_method, scheduling_method, instruction_durations, dt, approximation_degree, timing_constraints, seed_transpiler, optimization_level, callback, output_name, unitary_synthesis_method, unitary_synthesis_plugin_config, target) 302 303 # Transpile circuits in parallel --> 304 circuits = parallel_map(_transpile_circuit, list(zip(circuits, transpile_args))) 305 306 end_time = time()
~/anaconda3/envs/Braket/lib/python3.7/site-packages/qiskit/tools/parallel.py in parallel_map(task, values, task_args, task_kwargs, num_processes) 127 return [] 128 if len(values) == 1: --> 129 return [task(values[0], task_args, *task_kwargs)] 130 131 Publisher().publish("terra.parallel.start", len(values))
~/anaconda3/envs/Braket/lib/python3.7/site-packages/qiskit/compiler/transpiler.py in _transpile_circuit(circuit_config_tuple) 388 389 result = pass_manager.run( --> 390 circuit, callback=transpile_config["callback"], output_name=transpile_config["output_name"] 391 ) 392
~/anaconda3/envs/Braket/lib/python3.7/site-packages/qiskit/transpiler/passmanager.py in run(self, circuits, output_name, callback) 220 return circuits 221 if isinstance(circuits, QuantumCircuit): --> 222 return self._run_single_circuit(circuits, output_name, callback) 223 if len(circuits) == 1: 224 return self._run_single_circuit(circuits[0], output_name, callback)
~/anaconda3/envs/Braket/lib/python3.7/site-packages/qiskit/transpiler/passmanager.py in _run_single_circuit(self, circuit, output_name, callback) 275 """ 276 running_passmanager = self._create_running_passmanager() --> 277 result = running_passmanager.run(circuit, output_name=output_name, callback=callback) 278 self.property_set = running_passmanager.property_set 279 return result
~/anaconda3/envs/Braket/lib/python3.7/site-packages/qiskit/transpiler/runningpassmanager.py in run(*failed resolving arguments*) 122 for passset in self.working_list: 123 for pass_ in passset: --> 124 dag = self.do_pass(pass, dag, passset.options) 125 126 circuit = dag_to_circuit(dag)
~/anaconda3/envs/Braket/lib/python3.7/site-packages/qiskit/transpiler/runningpassmanager.py in do_pass(self, pass, dag, options) 155 # Run the pass itself, if not already run 156 if pass_ not in self.valid_passes: --> 157 dag = self.run_this_pass(pass, dag) 158 159 # update the valid_passes property
~/anaconda3/envs/Braket/lib/python3.7/site-packages/qiskit/transpiler/runningpassmanager.py in run_this_pass(self, pass, dag) 209 # Measure time if we have a callback or logging set 210 start_time = time() --> 211 pass_.run(FencedDAGCircuit(dag)) 212 end_time = time() 213 run_time = end_time - start_time
~/anaconda3/envs/Braket/lib/python3.7/site-packages/qiskit/transpiler/passes/utils/check_gate_direction.py in run(self, dag) 44 """ 45 self.property_set["is_direction_mapped"] = True ---> 46 edges = self.coupling_map.get_edges() 47 trivial_layout = Layout.generate_trivial_layout(*dag.qregs.values()) 48 if self.target is None:
AttributeError: 'NoneType' object has no attribute 'get_edges'
Similar error occurs when I try to directly get results by
result = qaoa.compute_minimum_eigenvalue(qubit_op)
The code works fine with other hardware, it seems only Rigetti has this problem.
3.14159
  • 41
Investigating a bit, this looks like it's due to the fact that the Rigetti device's operations aren't all global (there are certain qubits/pairs on which a gate may not be supported). As a result, Qiskit adds a gate direction check to the transpiler passes. However, the direction check relies on the coupling map, which isn't populated by the Qiskit-Braket provider. This looks like it's worth raising an issue for in the repo!
Cody Wang
  • 1,293
  • 13
