$\newcommand{\ket}[1]{\left|#1\right>}$Consider two qubits, $\ket{1}$ and $e^{i \theta}\ket{\psi}$ (what the qubits are doesn't actually matter). We express these in a single system using their tensor product, which would be $\ket{1} \otimes (e^{i \theta} \ket{\psi})$. The constant is free floating in the tensor product, so it can be expressed as $(e^{i \theta}\ket{1}) \otimes \ket{\psi}$. And so, you could say that the phase $e^{i \theta}$ belongs to the $\ket{1}$ qubit.
This post helped me, but didn't really answer my question entirely, https://physics.stackexchange.com/questions/77702/coefficients-of-the-vectors-in-a-tensor-product.
My question is, where does the phase belong? Is that even a question that makes sense asking? Does it not even matter, as it's global phase?
glS
  • 27,510
  • 37
  • 125
tpws
  • 145
We can write the total state as a tensor product of two qubits, but there is only one wavefunction of the total system. In fact $\vert1\rangle \otimes (e^{i\theta}\vert\psi\rangle)$ is exactly the same state as $(e^{i\theta}\vert1\rangle)\otimes\mid\psi\rangle$. The phase does not belong to either the first or the second qubit, it a property of the total state, i.e. a global phase.
Lord Nexprex
  • 123
What do you mean with "where does the phase belong"?
As you noted yourself, tensor products are defined so that $(\lambda v)\otimes w$ is the same element as $v\otimes(\lambda w)$, for any scalar $\lambda$. In other words, you can write the scalar however you like, it doesn't matter, the result element is the same. Which is why this would be generally written as $\lambda(v\otimes w)$, to point out that $\lambda$ is not "attached" to any particular vector.
And note that the above issue is distinct from it being a global phase or not, it holds in general for tensor products of vector spaces and the corresponding scalar fields. Then, as an added element, you have the fact that ket states are defined as vectors up to complex scalar multiplication. Which means that $\lambda |\psi\rangle$ and $|\psi\rangle$ represent the same physical state (and in a more careful treatment, they are completely identified). But this holds more generally, you don't need to tensor product structure for this statement.
glS
  • 27,510
  • 37
  • 125
