Given a complex unitary $2*2$ matrix $A$ that represents some quantum gate on a single qubit.
What is the formula to extract to $\theta_X, \theta_Y, \theta_Z $ rotations around each one of the axes in the Bloch Sphere?
I will mention that I know that :
$$U_3(\theta, \phi, \lambda) = \begin{pmatrix}\cos(\theta/2) & -e^{i\lambda}\sin(\theta/2) \\ e^{i\phi}\sin(\theta/2) & e^{i\lambda + i\phi}\cos(\theta/2)\end{pmatrix}$$
But while trying to use it, I struggled with $cos()=complex-value$ that gave me complex angles
ryanhill1
  • 2,623
  • 39
Ron Cohen
  • 1,512
  • 24
The Euler angles that you obtain depend on the decomposition that you implement over your 1 qubit gate. i.e it is possible to decompose any 1 qubit gate $U$ as:
$$ U = e^{i\gamma}R_z(\theta)R_y(\phi)R_z(\lambda)$$
or
$$ U = e^{i\gamma}R_z(\theta)R_x(\phi)R_z(\lambda)$$
In those cases, you'd obtain 2 $\theta_Z$ angles and 1 $\theta_Y$ or 2 $\theta_Z$ angles and 1 $\theta_X$ respectively. You can fin the methodology for some of the decompositions in this page:
https://purva-thakre.github.io/purva-blog/gsoc/qutip/single-qubit-example/
Qiskit has a class to implement several types of decompositions:
https://qiskit.org/documentation/stubs/qiskit.quantum_info.OneQubitEulerDecomposer.html
You can see the source code to know how they work:
https://qiskit.org/documentation/_modules/qiskit/quantum_info/synthesis/one_qubit_decompose.html#OneQubitEulerDecomposer
Andrés Ruiz
  • 232
