I know that one of the properties of the Kraus Operator is: $$\sum_k A_k^\dagger A_k=I\,.$$
So, in qiskit, I first converted my array to a super operator, and then I found my Kraus operators. However, the sum of the Kraus operator is not equal to the identity. And I do not know if I found my Kraus operator correctly or not. Here is my process matrix:
array([[ 1.   ,  0.   ,  0.   ,  0.   ],
       [ 0.001,  0.986,  0.02 ,  0.04 ],
       [ 0.014,  0.01 ,  0.019, -0.957],
       [-0.028, -0.031,  0.949,  0.008]])
Here is my code:
 q_process=qi.SuperOp(process)
 kraus_=qi.Kraus(q_process)
 kraus_
From kraus_, I put Kraus operators into kraus_list Here is how I found the sum of Kraus operators:
kraus_list = np.array([[[-0.833+0.j,  0.14 +0.j],
         [-0.14 +0.j, -0.821+0.j]],
    [[ 0.134+0.j,  0.812+0.j],
     [-0.806+0.j,  0.139+0.j]],
    [[ 0.14 +0.j, -0.06 +0.j],
     [-0.061+0.j, -0.142+0.j]],
    [[-0.012+0.j, -0.029+0.j],
     [-0.029+0.j,  0.012+0.j]],
   [[-1.168-0.j, -0.026-0.j],
     [ 0.014+0.j, -0.205-0.j]],
    [[ 0.201+0.j, -0.008-0.j],
     [ 0.021+0.j, -1.142-0.j]],
    [[ 0.004+0.j, -0.147-0.j],
     [ 0.16 +0.j,  0.005+0.j]],
    [[ 0.   +0.j, -0.032-0.j],
     [-0.03 -0.j, -0.   -0.j]]])
sum_of_kraus= np.matmul(kraus_list[0].conj().T,kraus_list[0])+np.matmul(kraus_list[1].conj().T,kraus_list[1])+np.matmul(kraus_list[2].conj().T,kraus_list[2])+np.matmul(kraus_list[3].conj().T,kraus_list[3])+np.matmul(kraus_list[4].conj().T,kraus_list[4])+np.matmul(kraus_list[5].conj().T,kraus_list[5])+np.matmul(kraus_list[6].conj().T,kraus_list[6])+np.matmul(kraus_list[7].conj().T,kraus_list[7])
Here is the result:
array([[2.843+0.j, 0.009+0.j],
       [0.009+0.j, 2.761+0.j]])
As it can be seen, it is not equal to identity. Could someone explain to me why I am finding 2.843 instead of 1. Am I doing something wrong in the code?
FDGod
  • 2,901
  • 31
quest
  • 704
Since OP never disclosed their solution let me shed light on what the mistake here was: the process matrix used as input was a Pauli transfer matrix (i.e. representation matrix in the Pauli basis) but qi.SuperOp uses the representation matrix in the computational basis. Converting OP's Pauli transfer matrix into the superoperator representation yields what the input should have been:
array([[ 0.49 +0.j , -0.0155-0.4745j , -0.0155+0.4745j , 0.482 +0.j   ],
       [ 0.0205 -0.4715j , 0.5025 -0.005j , 0.4835 +0.015j , -0.0195+0.4855j ],
       [ 0.0205 +0.4715j , 0.4835 -0.015j , 0.5025 +0.005j , -0.0195-0.4855j],
       [0.51 +0.j , 0.0155 +0.4745j , 0.0155 -0.4745j , 0.518 +0.j]])
Note that the code did what it is supposed to do: it interpreted the input as superoperator with respect to vectorization which leads to a map $\Phi$ that is not even completely positive or even Hermitian-preserving anymore. As a result qi.Kraus output generalized Kraus operators, i.e. matrices $A_1,\ldots,A_4,B_1,\ldots,B_4$ such that $\Phi=\sum_{k=1}^4 A_k(\cdot)B_k^\dagger$. Indeed, it is easy to check that the elements of kraus_list satisfy ${\rm superOp}(\Phi)=\sum_{k=1}^4\overline{B_k}\otimes A_k$ meaning they are indeed generalized Kraus operators of $\Phi$.
Frederik vom Ende
  • 4,163
  • 49
