It is often stated that some of the "hidden subgroup problems" can be efficiently solved by quantum computers if the group is abelian, while no efficient algorithm is known for the non-abelian case. The problems of the first case include factorization which is in NP (more precisely, there is a decision problem related to factorization that is in NP).
I would like to know if there is a general formulation of the abelian hidden subgroup problems as NP problems.
Adam Zalcman
  • 25,260
  • 40
  • 95
Doriano Brogioli
  • 511
  • 14
TL;DR: The general version of the Hidden Subgroup Problem (abelian or otherwise) is not in NP, because it is an oracle problem.
Background: $\text{NP}$
Recall that a language $L\subset \bigcup_{k=0}^\infty\{0,1\}^k$ belongs to $\text{NP}$ if there exists a deterministic Turing machine $M_L$ such that for every binary string $x\in L$ there exists a polynomial-size certificate $w$ with the property that the pair $(x,w)$ makes $M_L$ halt in polynomial time and answer "YES" and for every binary string $x\notin L$ all pairs $(x,w)$ make $M_L$ halt in polynomial time and answer "NO".
This definition has two important consequences. First, $\text{NP}$ is a class of decision problems. Second, $\text{NP}$ is a class of problems described as data on the input tape of a Turing machine. In particular, it excludes problems specified via access to an oracle.
We say that a function $f:G\to X$ from a finitely generated group $G$ to a finite set $X$ hides the subgroup $H$ of $G$ if $f(g_1)=f(g_2)\iff g_1g_2^{-1}\in H$. The Hidden Subgroup Problem $\text{HSP}$ is the following: given access to an oracle for $f$, find a set $S_H\subset G$ that generates the hidden subgroup $H$.
Clearly, $\text{HSP}$ is not in $\text{NP}$, because it is not a decision problem and because it is specified as an oracle for $f$.
Decision variant
We can easily remedy the first issue by defining the decision variant $\text{HSP}_D$ of the Hidden Subgroup Problem as the following: given access to an oracle for $f$, determine whether $H$ is trivial.
Oracles
However, we cannot turn $\text{HSP}$ into a problem that may be directly described on the input tape of a Turing machine without losing generality. Instead, we can ask a different question that captures the same overall intention as the original. Namely, we can ask whether $\text{HSP}_D$ belongs to the analogue of $\text{NP}$ for oracle problems. In other words, we can ask whether there exists easily checkable certificate that $H$ is a non-trivial subgroup of $G$.
I don't know whether this is the case for the general Hidden Subgroup Problem. However, consider the promise problem $\text{HSP}^h$ which is the same as $\text{HSP}$ except for the additional assumption that $X$ is a group and $f$ a group homomorphism. We can show that its decision variant $\text{HSP}_D^h$ has certificates that we can verify using a polynomial number of oracle queries.
$\text{HSP}_D^h$ has polynomially verifiable certificates
Suppose $f$ hides $H\subset G$. Note that $H$ is normal since it is the kernel of $f$. Let $S_H$ be a generating set of $H$ and $S_{G/H}$ a generating set of $G/H$. We can assume that $|S_H|\le\log|H|$ and $|S_{G/H}|\le\log|G/H|$ (see e.g. $A2.1.1$ on page $611$ in Nielsen & Chuang). The pair $(S_H,S_{G/H})$ is our certificate. Indeed, $f$ hides $H$ if and only if $f(h)=e$ for all $h\in S_H$ and $f(g)\ne e$ for all $g\in S_{G/H}$ where $e$ is the identity element of the group $X$. Moreover, by Lagrange theorem, the above test requires mere $|S_H|+|S_{G/H}|\le\log|G|$ invocations of the oracle.
In fact, the above certificate works for both positive and negative instances of $\text{HPS}_D^h$. Therefore, we have shown that $\text{HPS}_D^h$ belongs to the oracle analogue of $\text{NP}\cap\text{co-NP}$. Interestingly, factoring is known to be in $\text{NP}\cap\text{co-NP}$.
Adam Zalcman
  • 25,260
  • 40
  • 95
