I can run a circuit on IonQ through Azure Quantum, but I was wondering if I need to run the transpile function.
Asked
Active
Viewed 125 times
From Qiskit API Documentation, Submitting circuits to IonQ backends:
The IonQ provider provides access to the full IonQ Cloud backend, which includes its own transpilation and compilation pipeline. As such, IonQ provider backends have a broad set of "basis gates" that they will accept — effectively anything the IonQ API will accept:
['ccx', 'ch', 'cnot', 'cp', 'crx', 'cry', 'crz', 'csx', 'cx', 'cy', 'cz', 'h', 'i', 'id', 'mcp', 'mcphase', 'mct', 'mcx', 'mcx_gray', 'measure', 'p', 'rx', 'rxx', 'ry', 'ryy', 'rz', 'rzz', 's', 'sdg', 'swap', 'sx', 'sxdg', 't', 'tdg', 'toffoli', 'x', 'y', 'z']If you have circuits that you’d like to run on IonQ backends that use other gates than this (
uoriswapfor example), you will either need to manually rewrite the circuit to only use the above list, or use the Qiskit transpiler, per the example below. Please note that not all circuits can be automatically transpiled.
ryanhill1
- 2,623
- 1
- 11
- 39
