My question is the following
Let's assume I am using Steane concatenated code to do error correction. I consider that the stabilizers are extracted fault-tolerantly through the Steane method. The Steane code admits transversal Clifford operations but not the $T$-gate.
In order to implement this gate one method is to prepare an ancilla in a state:
$$|A_{\pi/4}\rangle = T |+ \rangle$$
and to then use quantum teleportation to implement the $T$ gate on the logical data qubit.
The preparation of such a state will usually fail with a high probability and to increase its probability of success we use the so-called magic state distillation procedure.
My question
Taking a step back I am not sure to understand why preparing $|A_{\pi/4}\rangle$ is more complicated than preparing the logical $|0\rangle$ for Steane code (where the stabilizers are measured fault-tolerantly with the Steane method) for instance.
Edit
As suggested in the answers, it might be easier to prepare the logical $|0_L\rangle$ and $|+_L\rangle$ because they can be prepared by measuring the stabilizers. For instance, you initialize all your physical data qubits in $|0\rangle$, you measure your stabilizers, and with that, you created the logical state $|0_L\rangle$.
However, with the Steane method I don't think it can work. Indeed, in order to measure stabilizers, we need additional ancillae qubits to do those measurements. And those ancillae must be prepared in the $|0_L\rangle$ or $|+_L\rangle$. Here you are just "moving" the problem because now you have to prepare fault-tolerantly those ancillae state. So I guess that if we use the Steane method to fault-tolerantly measure the stabilizers, we cannot initialize our data qubit in $|0_L\rangle$ by simply initializing all physical data qubits in $|0\rangle$ and then measuring the stabilizers.
Hence, my guess is that the reason for the hardness of initializing arbitrary logical states might be very dependent on the fault-tolerant construction that is considered.
It might not be much harder to prepare the $|0\rangle$ logical state or the $|A_{\pi/4}\rangle$ logical state for a fault-tolerant implementation based on the Steane method (because we cannot do the trick of measuring the stabilizers for reason given above). However, for surface code, we could do it because to measure stabilizers we only need to initialize physical ancilla in the physical $|0\rangle$ or $|+\rangle$ state. We don't have the issue of "infinite loop" as I just explained for the Steane method. But this trick would not work for an arbitrary state initialization (and then preparing the logical state $|A_{\pi/4}\rangle$ might become much harder than preparing $|0_L\rangle$).
Would you agree with me?
Marco Fellous-Asiani
  • 2,220
  • 15
  • 42
The point is the logical $|0\rangle$ and $|+\rangle$ are (relatively) easy to prepare. You start with any bunch of qubits, it doesn't matter what state. You simply measure the stabilizers of the code and one of the logical operators. Whatever answers you get, you can correct for the outcomes.
For a stabilizer code, you know what the logical operators are for $Z_L$ and $X_L$ - they're just strings of Pauli operators, and so the measurement is just as easy to implement as any of the stabilizer measurements. For $|A_{\pi/4}\rangle$, there isn't a corresponding logical operator to directly measure.
DaftWullie
  • 62,671
  • 55
  • 140
To prepare $|0_L\rangle$ in a CSS code, all you have to do is separately initialize all the data qubits into $|0\rangle$ and then start measuring the stabilizers of the code. The reason this works is because the stabilizers that protect $|0_L\rangle$ have a known value when all the data qubits are $|0\rangle$ (because they are Z type stabilizers). It's important that you know the stabilizers right from the start, since otherwise there would be a small moment of time where undetectable errors could sneak in before the first round of stabilizer measurements.
The same logic works for the $|+_L\rangle$ state, initializing data qubits into $|+\rangle$, and thereby knowing the X type stabilizers so you can detect any errors right from the start.
But initializing all the data qubits into $|i\rangle$ is not a fault tolerant way to prepare $|i_L\rangle$, even though $|i\rangle$ is a stabilizer state, because that initialization tells you none of the stabilizers' initial values. So you have no way of telling if there were errors affecting the logical observable between the initialization and the first round of stabilizer measurements. And actually, because $|i_L\rangle$ is vulnerable to both X and Z type logical errors, it needs all stabilizers to be deterministic instead of just the X types or the Z types. So it's even starting with a vulnerability penalty (in the context of a CSS code).
The same is true of the $|T\rangle = T|+\rangle$ state. Initializing all the data qubits into $|T\rangle$ randomizes all the stabilizers, so there's no foothold. In order for an initialization to be fault tolerant, it has to make deterministic all the stabilizers relevant to protecting that state. Otherwise you have no way of checking if an error happened between initialization and the first round of measurements. And the "easy" strategy of transversally initializing just doesn't work for non-trivial states like $|T\rangle = T|+\rangle$.
It's not that this is literally impossible. There are codes with fault tolerant T state initialization. It's just that the most obvious thing, transversal initialization in a CSS code, only works for $|0\rangle$ and $|+\rangle$.
Craig Gidney
  • 44,299
  • 41
  • 116
I agree with the two previously posted answers as answers to the original question.
However, further questions are asked in the extension/edit to the question. These new questions add up to roughly asking "how does fault tolerant state preparation of a stabilizer state work" which is a very good question. The best answer I've seen is Chapter 13 section 1 "Preparation of Encoded Stabilizer States" of Gottesman's new book, a pdf for which can be found here
https://www.cs.umd.edu/class/spring2024/cmsc858G/QECCbook-2024-ch1-15.pdf
note that not all 20 of the promised chapters are in the pdf, that is only because Gottesman has not finished writing the book. But what he has is already extremely interesting and informative on a lot of topics in quantum error correction and fault tolerance!
The content of section 13.1 "Preparation of Encoded Stabilizer States" relies heavily on the previous chapter 12 "Fault Tolerant Error Correction and Measurement." And understanding the way he describes things in chapter 12 requires at least skimming over the beginning of chapter 10 "Basics of Fault Tolerance." Section 13.1 also mentions non fault tolerant methods of preparing stabilizer states, it may be interesting/useful/informative to review those as well, they are discussed in Chapter 6 section 4 "Encoding Circuits for Stabilizer Codes."
