From the Qiskit textbook I read about Simon's algorithm. There are two n-wide quantum registers, so the general state is given by
$$|x\rangle_n|y\rangle_n$$
where x and y are the $2^n-1$ binary representations. A function from the n-subspace into n-subspace id defined by
$$f: |x\rangle\mapsto|f(x)\rangle$$
Now, the "query function" is given by the operation
$$|x\rangle|a\rangle \rightarrow |x\rangle |a \oplus f(x)\rangle$$
All building blocks in quantum computation shall be unitary transformations, so this mapping is unitary too - but how can I prove that this is really the case?
Is it enough to show, that norm is conserved like this:
Denoting
$$U|x\rangle|a\rangle = |x\rangle |a \oplus f(x)\rangle$$
I would have
$$\langle x| \langle a|U^\dagger = \langle x| \langle a \oplus f(x)|$$
so $$\langle x| \langle a|U^\dagger U |x\rangle |a\rangle= \langle x|x\rangle \langle a \oplus f(x)|a \oplus f(x)\rangle = 1 \cdot 1 = 1$$
But this appears a bit too trivial to be a prove...
glS
  • 27,510
  • 37
  • 125
MichaelW
  • 143
The easiest way to prove this is to apply the operator twice $$ |x\rangle|a\rangle\mapsto |x\rangle|a\oplus f(x)\rangle\mapsto |x\rangle|a\oplus f(x)\oplus f(x)\rangle=|x\rangle|a\rangle. $$ So, two applications of the function is the identity operation. Thus, the function is its own inverse, $U=U^{-1}$. Moreover, the eigenvalues must all be $\pm 1$, which shows that, for example, $U=U^\dagger$, and hence $UU^\dagger=I$, the standard relation for a unitary.
Incidentally, for what you tried to prove, is it clear that because, in a certain basis, all the lengths of those basis states are preserved, that the lengths of all possible superpositions of those states are also preserved?
DaftWullie
  • 62,671
  • 55
  • 140
