24
Is entanglement transitive, in a mathematical sense?
More concretely, my question is this:
Consider 3 qubits $q_1, q_2$ and $q_3$. Assume that
  • $q_1$ and $q_2$ are entangled, and that
  • $q_2$ and $q_3$ are entangled
Then, are $q_1$ and $q_3$ entangled? If so, why? If not, is there a concrete counterexample?
On my notion of entanglement:
  • qubits $q_1$ and $q_2$ are entangled, if after tracing out $q_3$, the qbits $q_1$ and $q_2$ are entangled (tracing out $q_3$ corresponds to measuring $q_3$ and discarding the result).
  • qubits $q_2$ and $q_3$ are entangled, if after tracing out $q_1$, the qbits $q_2$ and $q_3$ are entangled.
  • qubits $q_1$ and $q_3$ are entangled, if after tracing out $q_2$, the qbits $q_1$ and $q_3$ are entangled.
Feel free to use any other reasonable notion of entanglement (not necessarily the one above), as long as you clearly state that notion.
Sanchayan Dutta
  • 17,945
  • 50
  • 112
Peter
  • 529
TL;DR: It depends on how you choose to measure entanglement on a pair of qubits. If you trace out the extra qubits, then "No". If you measure the qubits (with the freedom to choose the optimal measurement basis), then "Yes".
Let $|\Psi\rangle$ be a pure quantum state of 3 qubits, labelled A, B and C. We will say that A and B are entangled if $\rho_{AB}=\text{Tr}_C(|\Psi\rangle\langle\Psi|)$ is not positive under the action of the partial transpose map. This is a necessary and sufficient condition for detecting entanglement in a two-qubit system. The partial trace formalism is equivalent to measuring qubit C in an arbitrary basis and discarding the result.
There's a class of counter-examples that show that entanglement is not transitive, of the form $$ |\Psi\rangle=\frac{1}{\sqrt{2}}(|000\rangle+|1\phi\phi\rangle), $$ provided $|\phi\rangle\neq |0\rangle,|1\rangle$. If you trace out qubit $B$ or qubit $C$, you'll get the same density matrix both times: $$ \rho_{AC}=\rho_{AB}=\frac12\left(|00\rangle\langle 00|+|1\phi\rangle\langle 1\phi|+|00\rangle\langle 1\phi|\langle\phi|0\rangle+|1\phi\rangle\langle 00|\langle0|\phi\rangle\right) $$ You can take the partial transpose of this (taking it on the first system is the cleanest): $$ \rho^{PT}=\frac12\left(|00\rangle\langle 00|+|1\phi\rangle\langle 1\phi|+|10\rangle\langle 0\phi|\langle\phi|0\rangle+|0\phi\rangle\langle 10|\langle0|\phi\rangle\right) $$ Now take the determinant (which is equal to the product of the eigenvalues). You get $$ \text{det}(\rho^{PT})=-\frac{1}{16}|\langle 0|\phi\rangle|^2(1-|\langle 0|\phi\rangle|^2)^2, $$ which is negative, so there must be a negative eigenvalue. Thus, $(AB)$ and $(AC)$ are entangled pairs. Meanwhile $$ \rho_{BC}=\frac12(|00\rangle\langle 00|+|\phi\phi\rangle\langle\phi\phi |). $$ Since this is a valid density matrix, it is non-negative. However, the partial transpose is just equal to itself. So, there are no negative eigenvalues and $(BC)$ is not entangled.
Localizable Entanglement
One might, instead, talk about the localizable entanglement. Before further clarification, this is what I thought the OP was referring to. In this case, instead of tracing out a qubit, one can measure it in a basis of your choice, and calculate the results separately for each measurement outcome. (There is later some averaging process, but that will be irrelevant to us here.) In this case, my response is specifically about pure states, not mixed states.
The key here is that there are different classes of entangled state. For 3 qubits, there are 6 different types of pure state:
  • a fully separable state
  • 3 types where there is an entangled state between two parties, and a separable state on the third
  • a W-state
  • a GHZ state
Any type of quantum state can be converted into one of the standard representatives of each class just by local measurements and classical communication between the parties. Note that the conditions of $(q_1,q_2)$ and $(q_2,q_3)$ being entangled remove the first 4 cases, so we only have to consider the last 2 cases, W-state and GHZ-state. Both representatives are symmetric under exchange of the particles: $$ |W\rangle=\frac{1}{\sqrt{3}}(|001\rangle+|010\rangle+|100\rangle)\qquad |GHZ\rangle=\frac{1}{\sqrt{2}}(|000\rangle+|111\rangle) $$ (i.e. if I swap qubits A and B, I still have the same state). So, these representatives must have the required transitivity properties: If A and B are entangled, then B and C are entangled, as are A and C. In particular, Both of these representatives can be measured in the X basis in order to localize the entanglement. Thus, any pure state that you're given must be such that you can include the measurement to convert it into the standard representative into the measurement for localizing the entanglement, and you're done!
DaftWullie
  • 62,671
  • 55
  • 140
This isn't an answer, but instead just some background facts that are important to know about in order to avoid "not even wrong" territory on these types of questions.
"Entanglement" is not all-or-nothing. Just saying "q1 is entangled with q2 and q2 is entangled with q3" is not enough information to determine the answer to questions like "if I measure q3, will q1 still be entangled with q2?". Entanglement gets complicated when dealing with larger systems. You really need to know the specific state, and the measurement, and whether you are permitted to condition on the result of the measurement.
It may be the case that q1,q2,q3 are entangled as a group but if you trace out any one of the qubits then the density matrix of the remaining two describes a mere classically correlated state. (E.g. this happens with GHZ states.)
You should be aware of the monogamy of entanglement. Past a certain threshold, increasing the strength of the entanglement between q1 and q2 must decrease the strength of entanglement between q1 and q3 (and equivalently q2 and q3).
Craig Gidney
  • 44,299
  • 41
  • 116
I read the following in Freudenthal triple classication of three-qubit entanglement:
"Dür et al. (Three qubits can be entangled in two inequivalent ways) used simple arguments concerning the conservation of ranks of reduced density matriceshere are only six three-qubit equivalence classes:
  • Null (The trivial zero entanglement orbit corresponding to vanishing states)
  • Separable (Another zero entanglement orbit for completely factorisable product states)
  • Biseparable (Three classes of bipartite entanglement: A-BC, B-AC, C-AB)
  • W (Three-way entangled states that do not maximally violate Bell-type inequalities) and
  • GHZ (maximally violate Bell-type inequalities)"
which as I understand it the answer to your question is yes: if A and B are entangled and B and C are entangled you necessarily are in one of the three-way entangled states so A and C are also entangled.
agaitaarino
  • 3,907
  • 13
  • 42
