11
Is there a working AWS Braket backend provider for Qiskit 0.29 that can be used with the MinimumEigenOptimizer interface? The qiskit-aws-braket-provider package is unfortunately not working.
glS
  • 27,510
  • 37
  • 125
Nepomuk Hirsch
  • 495
qbraid does!
qbraid has a transpiler for Qiskit <> Braket <> Pennylane (QNodes) <> Cirq <> Pyquil which is also backend compatible.
You'll have to sign up to access the SDK which can be done @ https://qbraid.com (it's free). The SDK should also have an opensource version at some point. Stay tuned!
Gaining access to the qBraid-transpiler
In terms of accessing the qbraid-sdk they have a youtube video which can get you started with credits etc for free! However, the qbraid CLI is frequently updated and checking the syntax to access various QCs (Rigetti, IONQ, OQC etc) by typing qbraid -h might be necessary in your qBraid Lab terminal.
They provide documentation for how their transpiler works here.
Check out the demo repo and an example from QCHack as well!
Hope this helps and if you have any questions just message me :)
The repository is now open source: https://github.com/qbraid/qbraid
ryoung98
  • 31
As a general follow-up on this question the qiskit-braket provider, https://github.com/qiskit-community/qiskit-braket-provider, mentioned earlier is actively monitored and maintained by both the open-source community as well as people at IBM and Amazon Braket. If there are limitations or bugs that you encounter when running Qiskit on Amazon Braket via that provider it is worth raising as an Issue in that GitHub repository.
ChristianM
  • 146
