I'm trying to simulate the effect of a coherent unitary Z rotation at an arbitrary angle of a single qubit on the fidelity of a quantum circuit. I am using the qiskit Aer noisy simulator. More specifically, my goal is to quantify the loss of fidelity associated with the fact that when attempting to apply any gate with a unitary $U$, I apply instead the gate
$$ V = R_{i,z}^\dagger(\epsilon)UR_{i,z}(\epsilon) $$
where $i$ is an index of a single qubit.
As a sanity check, I am trying the single qubit case first, where I expect this error to not have any effect, since the initial state of the qubit is $|0\rangle$ and the measurement is in the Z basis. Thus, assuming that the coherent unitary channel acts on the state as $\mathcal{E}(\rho) = U\rho U^\dagger$, this error should get absorbed into the preperation and measurement and not have any effect on the fidelity.
When I simulate this circuit however, I find that the fidelity does go below 1 as I increase the error. It seems like the qiskit method coherent_unitary_error function from qiskit does not return a QuantumError object which has the effect of applying $\mathcal{E}(\rho)$ as defined above. Does that make sense?
I am including here a self-contained code sample which shows this behavior. One easy way to trigger this effect on and off is to change the optimization_level parameter in line 21 of the attached code. If it is 0, then the two Hadamards don't get merged into one and we see an error. If it is 1 or larger, they get merged and no error appears. Of course, manually adding the Z rotations to the circuit does not lead to an error.
Any ideas? Did I misunderstand how the noise model works, or is there a more fundamental issue here?
Thanks a lot in advance!!
import qiskit
from qiskit import QuantumCircuit, transpile
from qiskit.providers.aer import AerSimulator
from qiskit.providers.aer.noise import NoiseModel, coherent_unitary_error
epsilon = 0.1
z_rot = qiskit.circuit.library.U1Gate(epsilon)
z_rot_dg = qiskit.circuit.library.U1Gate(-epsilon)
noise_model = NoiseModel()
noise_model.add_all_qubit_quantum_error(coherent_unitary_error(z_rot), 'u2')
noise_model.add_all_qubit_quantum_error(coherent_unitary_error(z_rot), 'u3')
print(noise_model)
noise_sim = AerSimulator(noise_model=noise_model)
circ = QuantumCircuit(1, 1)
circ.h(0)
circ.h(0)
circ.measure(0, 0)
change optimization level to 1 to turn off effect of channel
ct = transpile(circ, noise_sim, optimization_level=0)
print(ct.draw())
nshots=10000
job = noise_sim.run(ct, shots=nshots)
print(job.result().get_counts()['0']/nshots)
