I would like to expand upon this question: What is the probability of detecting Eve's tampering, in BB84?
Let's say that when the receiver (colloquially referred to as Bob) receives a qubit and measures it in the correct basis, the receiver still has a small percent chance of getting an incorrect measurement of the qubit due to noise. How does the protocol 'make room' for this error by accurately determining when the noise is a result of error, or a result of an eavesdropper?
Martin Vesely
  • 15,244
  • 32
  • 75
Quantum Guy 123
  • 1,499
  • 20
The standard noisy approach is not to try to determine the presence of an eavesdropper as such, but to create a final key where, even if there is an eavesdropper, you can still be confident that the eavesdropper has negligible information about the key. So you aren't trying to distinguish between noise and eavesdropping, but pessimistically assuming that all noise may be due to eavesdropping, and obtaining a key that is still private, even given this (or deciding that the noise level is too high for this to be possible).
This is done through privacy amplification - details of specific protocols (like Cascade) are covered in links others have posted, but essentially these are classical hashing protocols: classically, if you have a sequence of bits the eavesdropper has some partial information about, you can hash those down to a shorter sequence that the eavesdropper provably has negligible information about.
Proving the security of this approach for BB84 (including how much key, if any, can be obtained given a certain noise level) is more complicated, since the eavesdropper isn't limited to just knowing some fraction of the classical bits, they can do quantum attacks like entangling their own qubits with the ones in transmission. The Shor-Preskill proof of BB84's security (using some earlier work by Lo and Chau) works by showing that the protocol (with hashing) is equivalent to distillation of EPR entangled states from noisy entangled pairs, with EPR pairs being inherently uncorrelated (in a quantum or classical sense) with an eavesdropper.
GotCarter
  • 421
If there is an evasdroping, an error rate is higher than some long-term average of a quantum communication channel used for a quantum key distribution. So, when the error rate is high, the key is deleted and new one is distribuited again until noise level is at acceptable level.
A natural noise can be reduced with classical error correction, something like self-reparing codes.
See this thread for more information.
Martin Vesely
  • 15,244
  • 32
  • 75
I know that noise is a big challenge for running this protocol because it is hard to understand whether the error is produced by noise or eavesdropper. To make the success rate higher you assume that the noise is also caused due to eavesdropping. As you know this protocol heavily relies on probability calculations. So, while calculating the probability for eavesdropping, the noise is assumed to be included in it. The probability we achieve is enough to give information about the eavesdropper.
But, yeah if noise was removed we could get the exact probability values for eavesdropping.
sohamb172
  • 355
  • 15
