17
I am reading through the paper "Direct Fidelity Estimation from Few Pauli Measurements" (arXiv:1104.4695) and it mentions 'stabilizer state'.
"The number of repetitions depends on the desired state $\rho$. In the worst case, it is $O(d)$, but in many cases of practical interest, it is much smaller. For example, for stabilizer states, the number of repetitions is constant, independent of the size of the system..."
Adam Zalcman
  • 25,260
  • 40
  • 95
Quantum Guy 123
  • 1,499
  • 20
Let $\mathcal{G}_n$ denote the Pauli group on $n$ qubits. An $n$-qubit state $|\psi\rangle$ is called a stabilizer state if there exists a subgroup $S \subset \mathcal{G}_n$ such that $|S|=2^n$ and $A|\psi\rangle = |\psi\rangle$ for every $A\in S$.
For example, $(|00\rangle+|11\rangle)/\sqrt2$ is a stabilizer state, because it is a $+1$ eigenstate of the elements of the following four-element subgroup of $\mathcal{G}_2$: $\{II, XX, -YY, ZZ\}$.
Stabilizer states have a number of interesting properties. For example, they are exactly the states that are reachable from $|0\dots 0\rangle$ using the Clifford gates and thus, by Gottesman-Knill theorem, any quantum computation that takes place entirely in the set of stabilizer states can be simulated efficiently on a classical computer.
The significance of stabilizer states in Direct Fidelity Estimation (DFE) lies in the fact that they are a prime example of well-conditioned states. The cost of DFE on such states is relatively low.
Adam Zalcman
  • 25,260
  • 40
  • 95
