How can I transpile using universal $Clifford + T$ gates set? I have only seen examples using rotations + $CNOT$.
This is what I have tried
from qiskit import *
from qiskit.quantum_info import Operator
from qiskit.compiler import transpile
%matplotlib inline
u = Operator([[0, 0, 1, 0, 0, 0, 0, 0], [1, 0, 0, 0, 0, 0, 0, 0], [0, 1, 0, 0, 0, 0, 0, 0], [0, 0, 0, 1, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 1], [0, 0, 0, 0, 0, 1, 0, 0], [0, 0, 0, 0, 0, 0, 1, 0], [0, 0, 0, 0, 1, 0, 0, 0]])
qc = QuantumCircuit(3) qc.unitary(u, [0,1,2], label='u')
result = transpile(qc, basis_gates=['u1', 'u2', 'u3', 'cx'], optimization_level=3) result.draw(output='mpl')
And this example works fine. But when I was trying to set:
basis_gates=['h', 's', 't', 'cx']
It doesn't work. Could you help me, please?)
UPDATE: After comments I've tried this:
pip install git+https://github.com/LNoorl/qiskit-terra.git@feature/sk-pass
and then:
from qiskit.circuit import QuantumCircuit
from qiskit.circuit.library import TGate, HGate, TdgGate, SGate
from qiskit.transpiler.passes import SolovayKitaevDecomposition
%matplotlib inline
u = Operator([[1, 0, 0, 0, 0, 0, 0, 0], [0, 1, 0, 0, 0, 0, 0, 0], [0, 0, -1, 0, 0, 0, 0, 0], [0, 0, 0, 1, 0, 0, 0, 0], [0, 0, 0, 0, 1, 0, 0, 0], [0, 0, 0, 0, 0, 1, 0, 0], [0, 0, 0, 0, 0, 0, 1, 0], [0, 0, 0, 0, 0, 0, 0, 1]])
print('Orginal circuit:') print(qc)
basis_gates = [TGate(), SGate(), HGate()] skd = SolovayKitaevDecomposition(recursion_degree=2, basis_gates=basis_gates, depth=5)
discretized = skd(qc)
print('Discretized circuit:') print(discretized)
But it outputs only this:
Orginal circuit:
q_0: ┤0   ├
q_1: ┤1 u ├
q_2: ┤2   ├
q_0: ┤0   ├
q_1: ┤1 u ├
q_2: ┤2   ├
Where is a problem?
glS
  • 27,510
  • 37
  • 125
The reason for your second result is because unitary synthesis is not part of the SolovayKitaevDecomposition pass. Actually, you can combine your attempts to get the desired result.
This is the first stage (you first snippet), it will synthesise your circuit in terms of u* and cx:
from qiskit import QuantumCircuit
transpiled = transpile(qc, basis_gates=['u1', 'u2', 'u3', 'cx'], optimization_level=3)
Then you can transform it to Cliffort+T using SolovayKitaevDecomposition:
from qiskit.circuit.library import TGate, HGate, SGate
basis_gates = [TGate(), SGate(), HGate()] skd = SolovayKitaevDecomposition(recursion_degree=3, basis_gates=basis_gates, depth=5) discretized = skd(transpiled) print(discretized)
global phase: -0.063526
q_0: ┤ X ├┤ T ├┤ X ├┤ S ├┤ X ├┤ X ├┤ S ├┤ S ├┤ H ├───────────────────────────»
q_1: ──■─────────┼─────────■────┼──┤ X ├┤ S ├┤ S ├┤ S ├┤ X ├┤ S ├┤ H ├┤ TDG ├»
q_2: ────────────■──────────────■────■───────────────────■──┤ T ├┤ S ├─┤ S ├─»
luciano
  • 6,084
  • 13
  • 34
