"Quantum magic won't be enough" (Bennett et al. 1997)
If you throw away the problem structure, and just consider the space of $2^n$ possible solutions, then even a quantum computer needs about $\sqrt{2^n}$ steps to find the correct one (using Grover's algorithm) If a quantum polynomial time algorithm for a $\text{NP}$-complete problem is ever found, it must exploit the problem structure in some way. I've some (basic) questions that no one seems to have asked so far on this site (maybe because they are basic). Suppose someone finds a bounded error quantum polynomial time algorithm for $\text{SAT}$ (or any other $\text{NP}$-complete problem), thus placing $\text{SAT}$ in $\text{BQP}$, and implying $\text{NP} \subseteq \text{BQP}$.
Questions
The possibility (or not) to exploit the problem structure in a general enough (i.e. specific-instance independent) manner seems to be the very core of the $\text{P = NP}$ question. Now if a bounded error polynomial-time quantum algorithm for $\text{SAT}$ is found, and it must exploit the problem structure, wouldn't its structure-exploitation-strategy be usable also in the classical scenario? Is there any evidence indicating that such a structure-exploitation may be possible for quantum computers, while remaining impossible for classical ones?
Sources
Related
Didix
  • 815
Not necessarily. For example, Shor's algorithm exploits the structure of factoring in a way that classical computers can't. Specifically, Shor's algorithm looks for periods in the multiplicative subgroup of N-1 in a way that requires a quantum Fourier transform to be efficient.
Sometimes quantum algorithms do translate back into the classical domain. For example, you can use phase estimation to apply fractional QFTs in an efficient way. Translate this circuit directly into its classical equivalent, and you get an O(N log(N)) algorithm for fractional FFTs. But there's certainly no guarantees that what works well in the quantum context will work well in the classical context.
Craig Gidney
  • 44,299
  • 41
  • 116
