Weak Value Amplification is a procedure in which one consider a bipartite Hamiltonian of the form $H = g A \otimes B$, where $A$ is called system, $B$ is called meter and $g$ is the extremely small parameter we are interested to measure by amplification. The procedure goes as follows:
(1) The system and meter is initialized by some initial state $\vert\Psi\rangle=\vert\psi_{i}\rangle \otimes \vert \phi\rangle$. The evolution of the system $U = \exp(-igA \otimes B)$ is approximated to $1_{A}\otimes 1_{B}-ig A\otimes B$, since $g$ is extremely small. we get
$$U\vert\Psi_{i}\rangle\approx(1_{A}\otimes 1_{B}-ig A\otimes B)\vert\psi_{i}\rangle \otimes \vert \phi\rangle,$$ $$(1_{A}\vert\psi_{i}\rangle\otimes 1_{B}\vert \phi\rangle-ig A\vert\psi_{i}\rangle\otimes B\vert\phi\rangle).$$
(2) After the evolution, the system is post selected onto some final state $\vert\psi_{f}\rangle$ (which is nearly orthogonal to the initial state)
$$\langle\psi_{f}\vert U\vert\Psi_{i}\rangle\approx P_{s}(1_{B}\vert\phi\rangle - ig A_{w}B\vert\phi\rangle)$$.
Where $P_s = \langle\psi_{f}\vert\psi_{i}\rangle$ is the post-selection probability and $A_{w} = \langle\psi_{f}\vert A\vert\psi_{i}\rangle/P_{s}$ is called the weak value.
(3) If i re-exponentiate the above term, we get
$$\frac{\langle\psi_{f}\vert U\vert\Psi_{i}\rangle}{P_{s}}=\exp(-igA_{w}B)\vert\phi\rangle$$
where the exponential on the RHS is the Kraus operator acting on the meter intial state, using which one can estimate the small parameter $g$.
My attempt at solving:
(step 1) I prepare the initial state say psi1 and evolved the state according the Hamiltonian using mesolve for a short time t = np.linspace(0, 0.01, 50)
result = mesolve(H, psi1, t, c_ops = [], e_ops =[])
(step 2) The evolved state is result.states[49], but the problem I am facing is how do I make post-measurement on this with the final state?
One such dumb attempt, I did was taking the final state psif and sandwiched directly with result.states[49] as
eta = psif.dag()*result.states[49]
But my objective was to do the post-selection at a specific time, like say I weakly evolve the system for a short time say 0 to 0.1 seconds and do post-selection exactly at 0.05th second. I am really lost what to do from my (step 1). Is there a way to do post-selection in QuTiP at a specific time?
