In Classical Simulation of Quantum Error Correction in a Fibonacci Anyon Code, the authors state on page 2 in section I. Background, A. Topological model:
We consider a system supporting nonabelian Fibonacci anyon excitations, denoted by $\tau$. Two such anyons can have total charge that is either $\tau$ or $ \mathbb I$ (vacuum), or any superposition of these, and so the fusion space in this case is 2-dimensional. We can represent basis states for this space using diagrams of definite total charge for the Wilson loops, and arbitrary states as linear combinations of these diagrams:
For $n$ anyons of type $\tau$, the dimension of the fusion space grows asymptotically as $\varphi^n$, where $\varphi$ = $\frac{1+\sqrt 5}{2}$ is the golden ratio.
Observables associated with non-intersecting loops commute, and so a basis for the space can be built from a maximal set of disjoint, nested loops.
Finally, in "Coherence Frame, Entanglement Conservation, and Einselection" the authors state on page 3:
Preferred basis problem. From the method of CF, we discuss the preferred basis problem (PBP), which has been studied via the einselection approach [7, 8]. We will show, yet, the method of einselection is incomplete.
This method is described via the Stern-Gerlach experiment, as shown in the Fig. 1 of Ref. 7. The system is represented by the spin states (up and down) along some directions. One atom is put near one channel to serve as the apparatus to interact with the spin, causing entanglement. In this measurement, the PBP means that there is no physical difference between states
We also demonstrated that the preferred basis problem can be resolved more naturally by the method of coherence frame than the einselection method.
Question: Are there different bases for each part of the model. Is there a preferred basis for a qudit or does it depend upon the underlying technology used to implement the qudits. How is the basis integral to the control and measurement?
Note: This may be related to, but is not a duplicate of: What is meant by the term "computational basis"?, nor is one of the answers currently offered there an answer to this question.
Initially, efforts where made to address some comments but this only succeeded in making the question longer and less clear, I've stripped it down but the edits can be reviewed by the curious in the edit history.
