I am trying to solve the first question on the qiskit test which is writing a code for a full adder.
So based on my research if I have $A$ q[0], $B$ q[1] and $C$ in q[2] as input and Sum and Cout as output, I should be able to produce the correct outputs by the following gates:
q[0] XOR1 q[1] ---> q[4]
q[0] AND1 q[1] ---> q[3]
q[2] XOR2 q[4] ---> q[5] (SUM)
q[2] AND2 q[4] ---> q[6]
q[3] OR q[6] ---> q[7] (COUT)
Writing the following program I get that my answer is producing wrong results :
from qiskit import QuantumRegister, ClassicalRegister, QuantumCircuit
from qiskit import IBMQ, Aer, execute
build your quantum circuit here
#Define registers and a quantum circuit q = QuantumRegister(8) c = ClassicalRegister(2) qc = QuantumCircuit(q,c)
Preparing inputs
qc.x(q[0]) # Comment this line to make Qbit0 = |0> qc.x(q[1]) # Comment this line to make Qbit1 = |0> qc.x(q[2]) # Comment this line to make Qbit2 = |0> ( carry-in bit ) qc.barrier()
AND gate1 implementation
qc.ccx(q[0],q[1],q[3]) qc.barrier()
XOR gate1 implementation
qc.cx(q[0],q[4]) qc.cx(q[1],q[4]) qc.barrier()
XOR gate2 implementation
qc.cx(q[2],q[5]) qc.cx(q[4],q[5]) qc.barrier()
AND gate2 implementation
qc.ccx(q[2],q[4],q[6]) qc.barrier()
#OR gate implementation qc.cx(q[3],q[7]) qc.cx(q[6],q[7]) qc.ccx(q[3],q[6],q[7]) qc.barrier()
Measuring and put result to classical bit
( sum )
qc.measure(q[5],c[0])
( carry-out )
qc.measure(q[7],c[1])
execute the circuit by qasm_simulator
backend = Aer.get_backend('qasm_simulator') job = execute(qc, backend, shots=1000) result = job.result() count = result.get_counts() print(count) qc.draw(output='mpl')
Grading tells me that my results are not matching, but I cannot figure out what is wrong with my code. Thank you so much for help.
glS
  • 27,510
  • 37
  • 125
If I am correct, I suppose you are talking about the Qiskit Challenge 2020. A possible reason why your circuit is being graded wrong is because the question asks you to construct the circuit for full adder and give it the input $A=1$, $B=0$ and $X=1$. However, I think as per your code, you are preparing the qubits to be $|ABX\rangle = |111\rangle$ instead of $|101\rangle$. Baring that, your circuit works perfectly fine from what I could analyze.
Martin Vesely
  • 15,244
  • 32
  • 75
Tharrmashastha V
  • 404
  • 13
