I am new to quantum gates but do not understand the connection between the $RX$ and $X$ gates. I know that
$$R X(\theta)=\exp \left(-i \frac{\theta}{2} X\right)=\left(\begin{array}{cc} \cos \frac{\theta}{2} & -i \sin \frac{\theta}{2} \\ -i \sin \frac{\theta}{2} & \cos \frac{\theta}{2} \end{array}\right)$$
Meanwhile the $X$ gate is given by
$$X = \left(\begin{array}{cc} 0 & 1 \\ 1 & 0 \end{array}\right)$$
Is there a value of $\theta$ such that the two are the same? I see that choosing $\theta = \pi/2$ gives the result upto an overall factor of $-i$. Is that it or is there a deeper connection between the two gates? Is there a similar connection between the $Y$ and $RY$ gates and the $Z$ and $RZ$ gates such that the rotated gates are more general than the $X, Y$ and $Z$ gates?
You're almost correct - choosing $ \theta = \pi$ does yield $$ \begin{bmatrix} 0 & -i \\ -i & 0 \end{bmatrix} $$
Because this differs from the $X$ gate by a constant factor global phase ($ -i$), the gates are equivalent. (See here to learn more about the global phase).
This connection holds similarly for $ RY$ and $Y$, and $RZ$ and $Z$. A way to visualize this is the Bloch sphere: in essence, these gates are rotations about the $X, Y, Z$ axes (respectively):
Bloch sphere
So essentially our Pauli primitives are $\pi$ rotations over the respective axis.
C. Kang
  • 1,847
  • 24
