In PyQuil, a qubit is initialised as $|0\rangle$ by default. Suppose, I want to initialise a qubit in an arbitrary state, say $\frac{1}{\sqrt{3}}|0\rangle+\sqrt{\frac{2}{3}}|1\rangle$. How to do this arbitrary qubit initialisation in PyQuil?
Asked
Active
Viewed 92 times
As far as I know, you can only do this with the ReferenceDensitySimulator, which contains a set_initial_state method. This is unfortunate because density matrix simulation is very costly.
In your case:
from pyquil import Program
from pyquil.simulation import ReferenceDensitySimulator
from pyquil.pyqvm import PyQVM
from pyquil.gates import I
state_ket = np.array([1/np.sqrt(3), np.sqrt(2/3)])
state_bra = np.array([[1/np.sqrt(3)], [np.sqrt(2/3)]])
rho1 = state_ket * state_bra
prog = Program(I(0))
qam = PyQVM(n_qubits=1, quantum_simulator_type=ReferenceDensitySimulator)
must call reset() to change the current state of the density matrix
density_matrix = qam.wf_simulator.set_initial_state(rho1).reset()
qam.execute(prog)
np.testing.assert_array_equal(qam.wf_simulator.density, rho1)
Victory Omole
- 2,332
- 1
- 10
- 24
