Is there a way in Qiskit to initialize $n$ qubits with binary values (0s and 1s)? For example, how can I initialize two qubits in the state $|11\rangle$? Here is a code snippet:
from qiskit import QuantumCircuit
import numpy as np
n = 2 circuit = QuantumCircuit(n, n)
Seeking some sort of initialization routine like this
circuit.initializeQubits(initialState=np.ones(n), ...)
Define rest of the circuit
I am aware of the method in this tutorial, which is also referenced here and here. This method creates an arbitrary qubit state by defining an $N$ dimensional ($N = 2^n$) state vector of amplitudes. The problem with this method is it requires creating a state vector which is exponentially large. I'm trying to initialize the qubits by defining an $n$ dimensional binary vector, which for the above example would be [1, 1].
develarist
  • 995
  • 15
5 Answers5
qiskit-terra 0.16 or lower
As answered, probably the most canonical way to do this is with Statevector.from_label and initialize.
Here is the full example:
from qiskit import *
from qiskit.quantum_info import Statevector
n = 2 qc = QuantumCircuit(n)
qc.initialize(Statevector.from_label('1'*n).data, range(n)) qc.draw()
q_0: ┤0                     ├
     │  initialize(0,0,0,1) │
q_1: ┤1                     ├
You could confirm the result like this:
qc.measure_all()
execute(qc, backend=BasicAer.get_backend('qasm_simulator')).result().get_counts()
qiskit-terra 0.17 or higher
This questions inspired a new way to initialize a qubits in the basis states of the Pauli eigenstates Z, X, Y (à la Statevector.from_label).
from qiskit.extensions.quantum_initializer.initializer import Initialize
circuit = QuantumCircuit(6) circuit.append(Initialize("10+-lr"), range(6)) circuit.draw()
q_0: ┤0                         ├
q_1: ┤1                         ├
q_2: ┤2                         ├
     │  initialize(1,0,+,-,l,r) │
q_3: ┤3                         ├
q_4: ┤4                         ├
q_5: ┤5                         ├
The decomposition of this gate is the following:
circuit.decompose().draw()
q_0: ─|0>─┤ H ├─┤ S ├─
q_1: ─|0>─┤ H ├┤ SDG ├
q_2: ─|0>─┤ X ├─┤ H ├─
q_3: ─|0>─┤ H ├───────
q_4: ─|0>─────────────
q_5: ─|0>─┤ X ├───────
luciano
  • 6,084
  • 13
  • 34
You can also create a Statevector, that can be directly initialized as follows:
sv = Statevector.from_label('11')
You can use sv.evolve(qc) to apply an operator/circuit to the state, where qc is the operator/circuit. sv.data gives you the numpy array, containing the actual implementation of the state.
Check this for more details.
e-eight
  • 302
Qiskit assumes that initially each qubitt is set to the $|0\rangle$ state. So if you have $n$ qubits, the initial state is $|00..0\rangle$. If you want to flip the state of some specific qubits, you have to apply an $X$ gate to each of those specific qubits. For example, the following code sets the $|11\rangle$ state:
qr = QuantumRegister(2)
cr = ClassicalRegister(2)
circuit = QuantumCircuit(qr, cr, name='mycircuit')
circuit.x(qr[0])
circuit.x(qr[1])
Michele Amoretti
  • 1,594
may be you can define a function like below
def qubitinitialize(n,n_init):
#n = number of qubits
#n_init = initial state of each qubit
    for i in n_init:
        if i == 1:
            qc.x(i)
return(qc)
This function will return a circuit with initial state as you provide in n_init
n = 4  #number of qubits
n_init = [0,0,1,0] #a bit string of qubit initialization we need
qc_n = qubitinitialize(n,n_init)
qc_n.draw('mpl')
just remember that 0,1,2,3 in the bit string will convert to q3,q2,q1,q0
kalyan
Aer simulators will support what you're looking for very soon: https://github.com/Qiskit/qiskit-aer/pull/834
Yael Ben-Haim
  • 879
