Program.qs
namespace Quantum.Kata.SingleQubitGates {
    open Microsoft.Quantum.Intrinsic;
    open Microsoft.Quantum.Math;
 operation GlobalPhaseI (q : Qubit) : Unit is Adj+Ctl {
    X(q);
    Z(q);
    Y(q);
Reference.qs
operation GlobalPhaseI_Reference (q : Qubit) : Unit is Adj+Ctl {
    X(q);
    Z(q);
    Y(q);
Test.qs
    open Microsoft.Quantum.Canon;
    open Microsoft.Quantum.Diagnostics;
    open Microsoft.Quantum.Convert;
operation ControlledArrayWrapperOperation (op : (Qubit => Unit is Adj+Ctl), qs : Qubit[]) : Unit is Adj+Ctl {
    Controlled op([qs[0]], qs[1]);
operation AssertEqualOnZeroState (testImpl : (Qubit => Unit is Ctl), refImpl : (Qubit => Unit is Adj+Ctl)) : Unit {
    using (qs = Qubit[2]) {
        within {
            H(qs[0]);
        apply {
            Controlled testImpl([qs[0]], qs[1]);
            Adjoint Controlled refImpl([qs[0]], qs[1]);
        AssertAllZero(qs);
operation T2_GlobalPhaseI_Test () : Unit {
    AssertOperationsEqualReferenced(2, ControlledArrayWrapperOperation(GlobalPhaseI, _), ControlledArrayWrapperOperation(GlobalPhaseI_Reference, _));
Driver.cs
using Microsoft.Quantum.Simulation.XUnit;
using Microsoft.Quantum.Simulation.Simulators;
using Xunit.Abstractions;
namespace Quantum.Kata.SingleQubitGates { public class TestSuiteRunner { private readonly ITestOutputHelper output;
    public TestSuiteRunner(ITestOutputHelper output)
        this.output = output;
    /// <summary>
    /// </summary>
    [OperationDriver(TestNamespace = "Quantum.Kata.SingleQubitGates")]
    public void TestTarget(TestOperation op)
        using (var sim = new QuantumSimulator())
            sim.OnLog += (msg) => { output.WriteLine(msg); };
            sim.OnLog += (msg) => { Debug.WriteLine(msg); };
            op.TestOperationRunner(sim);
Yes, this sequence of gates will work to apply the global phase of $i$. You can check it using matrix multiplication - a product of matrices $Y \cdot Z \cdot X$ will give you a matrix $\begin{bmatrix} i & 0 \\ 0 & i \end{bmatrix}$, which corresponds to applying a global phase.
Alternatively, you can implement it using R gate with the phase $-\pi$: R(PauliI, -PI(), q);
As a side note, performing measurements this way is not going to detect a global phase introduced by the gate; you need to work with a controlled version of the gate to detect it.
Mariia Mykhailova
  • 9,285
  • 13
  • 40
On IBM Q, you can also use $U3$ gate to prepare a global phase operator. $U3$ gate is defined as $$ U3(\theta, \varphi, \lambda) = \begin{pmatrix} \cos (\theta/2) & -\mathrm{e}^{i\lambda}\sin(\theta/2) \\ \mathrm{e}^{i\varphi}\sin(\theta/2) & \mathrm{e}^{i(\varphi + \lambda)}\cos(\theta/2)\\ \end{pmatrix}. $$ Setting $\theta = \pi$ we get $$ U3(\pi, \varphi, \lambda) = \begin{pmatrix} 0 & -\mathrm{e}^{i\lambda} \\ \mathrm{e}^{i\varphi} & 0\\ \end{pmatrix}. $$ Let's denote our global phase $\alpha$ and set $\varphi = \alpha$ and $\lambda = \alpha + \pi$. Since $-\mathrm{e}^{i\pi}=1$ we have $$ U3(\pi, \alpha, \alpha+\pi) = \begin{pmatrix} 0 & \mathrm{e}^{i\alpha} \\ \mathrm{e}^{i\alpha} & 0\\ \end{pmatrix}, $$ which is $\mathrm{e^{i\alpha}}X$. To get $\mathrm{e^{i\alpha}}I$, we apply another $X$ gate.
So, global phase gate is implemented as $X\,\,U3(\pi,\alpha,\alpha+\pi)$, where $\alpha$ is global phase.
EDIT (solution in Q#)
A $R1$ gate is defined as $$ R1(\theta) = \begin{pmatrix} 1 & 0 \\ 0 & \mathrm{e}^{i\theta} \end{pmatrix} $$
An operation $X\,R1(\theta)$ is described by matrix $$ \begin{pmatrix} 0 & \mathrm{e}^{i\theta} \\ 1 & 0 \end{pmatrix} $$
If we apply this operation twice (i.e. $[X\,R1(\theta)]^2$ ), we get
$$ \begin{pmatrix} \mathrm{e}^{i\theta} & 0 \\ 0 & \mathrm{e}^{i\theta} \end{pmatrix}, $$
which is a global phase gate with arbitrary phase $\theta$.
So, global phase gate in Q# can be realized as $[X\,R1(\theta)]^2$.
Martin Vesely
  • 15,244
  • 32
  • 75
I apologize, but I can not comment on @Martin Vesely answer above. I am glad that my amendments have already been adopted, I’ll leave only a short note, in case someone is interested in this: In Qiskit programs (e.g. see) I use X before U3 in my variants of phase shift circuits, in an attempt to avoid "distortion" during further processing of Qiskit (for example, by transpiler):
qc.x(qubit)
qc.u3(np.pi, gamma, np.pi + gamma, qubit)
If not for similar considerations, then the order here would not be important (as in other similar cases, e.g. $[X\,R1(\theta)]^2 = [R1(\theta)\,X]^2$)
