I have a sort of basic question. I think an operator that acts on $n$-partite states is defined (up to permutation of parties) to be local if it can be written as
$$A = A_1 \otimes_{i=2}^n \mathbb{I}_i $$
where the subscript $i$ denotes the party on which an operator acts. This definition ensures that $A$ is acting only on one party (here we are assuming that each party is spatially separated from the rest). So far so good. The problem comes when I consider concatenation of operators. Consider for instance a 3-qubit system, and consider the local operators
$$\mathcal{O}_1 = Z_1 \otimes \mathbb{I}_2 \otimes \mathbb{I}_3 \, , \quad \mathcal{O}_2 = \mathbb{I}_1 \otimes Z_2 \otimes \mathbb{I}_3 \, , \quad \mathcal{O}_3 = \mathbb{I}_1 \otimes \mathbb{I}_2 \otimes Z_3 \, , $$
i.e. $\mathcal{O}_i$ applies the $Z$ gate to party $i$ and does nothing to the rest. If Alice performs $\mathcal{O}_1$, then Bob performs $\mathcal{O}_2$ and then Charlie performs $\mathcal{O}_3$, which I understand is a protocol within the LOCC rules (actually no communication is needed at all) then the resulting gate is
$$ \mathcal{O}_3 \mathcal{O}_2 \mathcal{O}_1 = Z_1 \otimes Z_2 \otimes Z_3 \, ,$$
which I would say is a non-local operator. How is it that a succession of local operators gives rise to a non local operator?
MBolin
  • 316
This depends on the context in which you're using the operators. You're talking about multiplying them, so I guess you're thinking of, for example, unitaries (and other circuit model elements). In this case, not only are terms $A\otimes I$ local operators, but $A\otimes B$ is also a local operator. For example, on a quantum circuit, two Hadamard gates applied on neighbouring qubits are described as $H\otimes H$.
It is only when you take sums of local operators that you might create a non-local operator. For example, controlled-not is written as $I\otimes I+(I-Z)\otimes(X-I)/4$, and cannot be written in the form $A\otimes B$, corresponding with the fact that it's entangling. Given that this is the setting I believe you're talking about, everything in your question is considered a local operator.
The other context in which this might arrise is a Hamiltonian. If you have a Hamiltonian that is of the form $H=A\otimes I$, that Hamiltonian is local. However, a Hamiltonian $H=A\otimes B$ is not local. There is no contradiction here because you do not combine local Hamiltonians by product, but by adding them together, so there is no expectation that $A\otimes B$ should be local. Ultimately, what you're really thinking about is the resultant evolution, $e^{-iHt}$. There, you can see that $H=A\otimes B$ produces unitaries that are non-local in the previous sense, while if I added local operators, $H=A\otimes I+I\otimes B$, that produces local operators $e^{-iAt}\otimes e^{-iBt}$ in the same sense as before.
DaftWullie
  • 62,671
  • 55
  • 140
There are two inequivalent definitions of "local operator" used in quantum information theory.
The first definition is used in the context of communication over a classical channel (e.g. LOCC). In this context, you have a fixed partition of the complete Hilbert space into a tensor product of $k$ different subsystems, and the subsystems are assumed to be so far apart that no entangling operator can ever act on both of them. In this context, a "local operator" is defined to be an operator that can be expressed as a tensor product of operators that only act on an individual subsystem, i.e. $\bigotimes_{i=1}^k A_i$, where the operator $A_i$ acts on the $i$th subsystem. Under this definition, the product of local operators is always a local operator, because by definition $\left (\bigotimes_{i=1}^k A_i \right) \left( \bigotimes_{i=1}^k B_i \right) = \bigotimes_{i=1}^k (A_i B_i)$.
The second definition is primarily used in the context of many-body quantum physics, e.g. topological quantum computing. Here, a local operator isn't defined to act nontrivially on only one qubit, but instead on a fixed number of qubits (generally up to four in practice) that does not depend on the total number of qubits in the circuit. So for example a single operator that acts on all the qubits, or a fixed fraction of the qubits, would not count as local. The idea is that as the number of qubits gets large, the operator acts on a negligible small fraction of the total.
When thinking about hardware implementations of a quantum computer, there's sometimes also a natural sense in which some qubits are "next to" each other. In hardware implementations, it's usually easier to engineer multi-qubit gates that act on qubits that are physically close together. In this case, "local" can refer to gates that only act on qubits that are a maximum physical distance away (which will depend on the geometry in which they're laid out). Under this second definition, the product of local operators will in general be non-local if they act on qubits that are sufficiently far apart.
tparker
  • 2,939
  • 13
  • 26
