35
Do atoms have any uniquely identifying characteristic besides their history?
For example, if we had detailed information about a specific carbon atom from one of Planck's fingerprints, and could time-travel to the cosmic event in which the atom formed, would it contain information with which we could positively identify that they two are the same?
Fundamental particles are identical.
If you have two electrons, one from the big bang and the other freshly minted from the LHC, there is no experiment you can do to determine which one is which. And if there was an experiment (even in principle) that could distinguish the electrons then they would actually behave differently.
Electrons tend to the lowest energy state, which is the innermost shell of an atom. If I could get a pen and write names on all of my electrons then they would all fall down into this state. However since we can't tell one electron from another only a single (well actually two since there are two spins states of an electron) electron will fit in the lowest energy state, every other electron has to fit in a unique higher energy level.
Edit: people are making a lot of comments on the above paragraph and what I meant by making electrons distinguishable, so I will give a concrete example: If we have a neutral carbon atom it will have six electrons in orbitals 1s2 2s2 2p2. Muons and tauons are fundamental particles with very similar properties to the electron but different masses. Muons are ~200 times more massive than electrons and tauons are ~3477 times more massive than an electron.
If we replace two of the electrons with muons and two of the electrons with tauons all of the particles would fall into the lowest energy shell (which can fit two of each kind because of spin). If in theory these particles only differed in mass by 1% or even 0.0000001% they would still be distinguishable and so all fit on the lowest energy level.
Now atoms are not fundamental particles they are composite, I.E. composed of "smaller" particles, electrons, protons and neutrons.
Protons and neutrons are themselves composed of quarks. But because of the way that quarks combine, they tend to always be in the lowest energy level so all protons can be considered identical, and similarly with neutrons.
To take the example of carbon, there are several different isotopes, different number of neutrons, of carbon (mostly 12C but also ~1% 13C and ~0.0000000001% 14C {the latter which decays with a half life of ~5,730 years [carbon dating] but is replaced by reactions with the sun's rays in the upper atmosphere}).
If we take two 12C atoms, and force all of the spins to be the same. This is not too difficult for the electrons of the atom since the inner electrons do not have a choice of spin because every spin in every level is already full. So only outer electrons matter. The nucleons also have spin.
With our two 12C atoms with all of the same spins, we now have two indistinguishable particles which if you set up an appropriate experiment (similar in principle to the electrons not being able to occupy the same state) we will be able to experimentally prove that these two atoms is indistinguishable.
Answer time:
Are atoms unique?
No.
Their history of a particle does not affect it*. No particles are unique. Atoms may have isotopes or spin to identify one from another, but these are not unique from another particle with the same properties.
Yes only because we could positively identify that this carbon atom is the same as almost every other carbon atom in existence.
*Unless it does, in which case it may be considered a different particle with different properties.
user288447
  • 1,954
10
Does position count as a characteristic? If so, then yes, atoms do have unique characteristics.
Edit: Perhaps I should rephrase this. If position counts as a characteristic, then yes, atoms do have unique characteristics.
user37390
  • 676
I'm going to add to user288447's answer, with which I concur, by adding that the evidence for this comes from Thermodynamics (at least that's where I learned about it, the principle is reflected everywhere). If the identity of individual particles mattered, then the way that entropy changes when you separate a group of particles from each other would be very different. This is only reiterating what's been said, that you can't construct an experiment that distinguishes particles from each other, but what fascinated me when I learned this is that you can also say "experiment has consistently shown that particles with the same properties are indistinguishable."
krs013
  • 1,791
  • 13
At the atomic level, atoms have very few distinguishing characteristics. These are the result of different number and amounts of electrons, protons, neutrons, etc. as outlined in the periodic table of the elements. However, when talking about a specific element like carbon, there is no difference between a carbon particle created 4 billion years ago or one created today. The measurable characteristics of carbon are tied directly to the number of electrons protons, neutrons, etc., and its geometry. A carbon particle made today has the same composition and geometry of a carbon particle made any time in the past. Since their properties are the same and independent of the method used to create them, they are indistinguishable, and poses no history. The only way we could know that they were created at different dates, would be from information obtained outside of the particles.
Guill
  • 2,573
