With the FLRW equations we can get solutions for a matter dominated closed universe in which the finale is an ultimate collapse, but this is only in terms of $a$ (the scale factor) and $t$ (time) and some $q_0$ and $\theta$:
$a = {\frac {q_0}{2 q_0 -1 } } (cosh (\theta) -1) $, (1)
$t = {\frac {q_0}{2 q_0 -1 } } (sinh(\theta) - \theta)$ (2)
where $dt=a d\theta$
Unfortunately, the FLRW does not show that the model should collapse into a black hole. So it only tells you when things might end depending on $q_0$. So I will appreciate if someone can give me an opinion of whether the following solution is appropriate for a universe that has collapsed into a black hole. Please feel free to rip it apart if necessary. And secondly, how can the final black hole equation be factored into the FLRW solution to get a complete model? Here it goes.
First the energy of the matter is simply:
$E_{m}= M c^2$ (3)
The gravitational potential energy $U$ of the universe is (see http://arxiv.org/abs/1004.1035):
$U = - \frac {3 G M^2} {5 R}$ (4)
For a particle away from the event horizon the Newtonian gravity is simply:
$g r^2 = G M $ (5)
where $r$ is the radial coordinate of the observer. If I assume that $U = E$ once the universe has completely collapsed then I get,
$Mc^2 = - \frac {3 G M^2} {5 R}$ (6)
Substituting (5), I get:
$c^2 = - \frac {3 r^2 g}{5R}$ (7)
And finally,
$R = - \frac{3}{5} \frac {r^2 g}{c^2}$ (8)
Now it turns out that the formula for the Schwarzschild radius in Newtonian gravitational fields is remarkably similar http://en.wikipedia.org/wiki/Schwarzschild_radius):
$R_s = 2 \frac {r^2 g} {c^2}$ (9)
The obvious issue here is that I got the constant $-3/5$ instead $2$. So the real question now is, are these computations correct and there is a reason for the difference? (for example, a supermassive BH Universe is not the same as your conventional BH). Or is it this a completely wrong approach that yields a completely wrong answer? If wrong, what is the right answer? Note that I tried to avoid solutions with $M$ and $G$ because that results in absurd answers such as those arrived in If the observable universe were compressed into a super massive black hole, how big would it be? (i.e., the radius of the BH would turn out larger than the current radius of the Universe, etc, etc).
Luis
  • 331
  • 13
