54
There are a number of possible symmetries in fundamental physics, such as:
  • Lorentz invariance (or actually, PoincarĂ© invariance, which can itself be broken down into translation invariance and Lorentz invariance proper),
  • conformal invariance (i.e., scale invariance, invariance by homotheties),
  • global and local gauge invariance, for the various gauge groups involved in the Standard Model ($SU_2 \times U_1$ and $SU_3$),
  • flavor invariance for leptons and quarks, which can be chirally divided into a left-handed and a right-handed part ($(SU_3)_L \times (SU_3)_R \times (U_1)_L \times (U_1)_L$),
  • discrete C, P and T symmetries.
Each of these symmetries can be
  • an exact symmetry,
  • anomalous, i.e., classically valid but broken by renormalization at the quantum level (or equivalently, if I understand correctly(?), classically valid only perturbatively but spoiled by a nonperturbative effect like an instanton),
  • spontaneously broken, i.e., valid for the theory but not for the vacuum state,
  • explicitly broken.
Also, the answer can depend on the sector under consideration (QCD, electroweak, or if it makes sense, simply QED), and can depend on a particular limit (e.g., quark masses tending to zero) or vacuum phase. Finally, each continuous symmetry should give rise to a conserved current (or an anomaly in the would-be-conserved current if the symmetry is anomalous). This makes a lot of combinations.
So here is my question: is there somewhere a systematic summary of the status of each of these symmetries for each sector of the standard model? (i.e., a systematic table indicating, for every combination of symmetry and subtheory, whether the symmetry holds exactly, is spoiled by anomaly or is spontaneously broken, with a short discussion).
The answer to each particular question can be tracked down in the literature, but I think having a common document summarizing everything in a systematic way would be tremendously useful.
Gro-Tsen
  • 850
I'd say that there is not a systematic summary of the status of symmetries on particle physics, but if any, it should be spread all over the PDG review.
However, I'd like to comment on a few points.
  • So far Lorentz symmetry is exact on all sectors.${}^\dagger$
  • Scaling (part of the conformal transformations) is broken once an energy scale is introduced in the theory. Therefore, you can not extend the Lorentz group symmetry to a conformal symmetry.${}^{\dagger\dagger}$ The existence of masses breaks explicitly this symmetry (and also the global chiral symmetry).
  • Gauge symmetry can be broken spontaneously. Because it is the only way we know for breaking the symmetry and still preserve desirable properties!
  • Anomalies aren't bad! As long as they are related with global transformations, not related with the gauge symmetries.
  • Flavour "symmetries"... They are not, unless fermion masses vanish.
  • $C$, $P$ and $T$, mathematically we expect that $CPT$ is a symmetry, but they aren't conserved individually.${}^{\dagger\dagger\dagger}$
Despite all of this, tomorrow our understanding of the symmetries of the Universe might change radically! (Kind of love this uncertainty!)
${}^\dagger$ NOTE: exact does not mean in the literal way, but only that if it's broken the scale is outside our current measurement limits.
${}^{\dagger\dagger}$ Although pure gauge theories could posses a conformal symmetry, it makes no sense to consider "free" theories.
${}^{\dagger\dagger\dagger}$ $CP$ is known to be violated (specially in the electroweak sector, and there is the known strong $CP$ problem).
PhotonBoom
  • 5,350
Dox
  • 1,778
A pretty exhaustive summary in the context of Standard Model already exists in the following source:
''Dynamics of the Standard Model'' - Donoghue, Golowich, Holstein,
Chapter 3 - Symmetries and Anomalies
A limited preview can be found here. (Embarrassingly though, the very first page of the chapter is excluded from Google's preview!)
But here's the issue I have with my ''answer''. The way I read your question:
This is a classic resource recommendation question, and as far as I know, ''link-only'' answers aren't welcome with this brand of questions. But, even if I ''summarize'' that chapter, I would be merely reproducing information which is already existing in this reference, so my ''effort'' is only to create a table based on that information. While I would've sufficiently bent around the rules by doing it, isn't that a stupid thing to do?
299792458
  • 3,214
