As the title suggests I was wondering why the International Bureau of Weights and Measures decided a mole to be a standard (SI-)unit. After some research I found I was not alone with this problem.
The core of my question is:
- How is the unit “mole” necessary as a standard unit?
- If mole is the standard unit, why wouldn't I have a give all numbers in mole?
Of course a mole is a convenient unit but I can't see how it is as fundamental as i.e. a meter, as it is clearly based on the concept of counting the atoms.
EDIT: Due to the first answer I got I realized my question is probably misleading: by fundamental I do not mean dictated by nature but considered a base unit. The need of units is obvious in the case of meters and seconds: no matter how you want to measure time or length, you will necessarily have to compare it to some standard (in this case meter and seconds, independently of how they are defined). In the case of "number of particles" this is not needed, instead one could say they are compared to "1". This is normally not considered a unit. Is this difference only a personal opinion?
