According to Huygens principle, if we consider any point of the primary wave fronts, each point is the source of secondary disturbance. If the point size we consider tends to zero, the number of points on that wave front which enters the slit tends to infinity. Thus, if we consider the slit how much ever small, we must see the diffraction pattern. Because we can consider many points on the wave front that enter slit, whose size is very very small-thus producing interference of waves emanating from them which can give diffraction pattern. But in reality as I know we don't see any diffraction pattern if we have the slit of very small in width compared to wavelength. Is the point size that we consider in diffraction is restricted to some value? If not as explained above, we can have many points of very very small size on the wave front that enter the slit, and we can expect diffraction even if slit size is tending to zero.
I don't know whether I have misunderstood anywhere, if yes pardon me and explain. If not, is it that (according to huygens principle) we can observe diffraction pattern even if slit size is tending to zero?
Sometimes I might not be communicating with you better with my problem, if so please comment on where there is problem.
Sensebe
  • 5,889
Actually there is always diffraction through a slit, in theory no matter how thin: it's simply that the penetration of light through a less-than-wavelength-wide slit becomes fantastically inefficient as the slit width narrows down. As in fffred's answer, one can look at this as a statistics problem. fffred's answer also raises an excellent practical limit that arises because the screen is made of atoms whose electrons will "plug" a very small gap. So I shall explore the theoretical case where the screen is a theoretical continuum and show that without the limit cited in fffred's answer, that there will always be some diffraction from an arbitrarily narrow slit. The field beyond the slit has two components: (i) a radiative component comprising propagating plane waves and (ii) an evanescent field that does not propagate but dwindles in amplitude exponentially with distance from the screen. As the slit narrows down, the field's character becomes overwhelmingly that of the evanescent former, but there is always a tiny bit of radiation. The problem you are thinking about is very nearly related to the idea of quantum tunnelling.
Before I get too theoretical, there is a practical way to understand this in terms of more everyday things. If an arbitrarily small slit did not radiate at all, there would be no way for a fluorophore (an excited atom) to radiate. Fluorophores are fractions of nanonmetres wide, roughly a thousandth of a wavelength, yet they still have a nonzero coupling co-efficient with the free-photon, radiative electromagnetic field. You can think of them as exactly like electric dipole antennas (this picture still holds by the way in the description of the physical system in terms of photons, see my answer here for more info): your now-swiftly-becoming-antique AM table radio interacts perfectly well with the electromagnetic field even though it may be a few centimetres wide tuning in to an AM signal of a hundred metres wavelength. And it also radiates as it receives, that's why the TV detector man can get you if you live in the UK and run a radio or television without a licence. Moreover, AM band transceivers exist and work perfectly well, even though the transmitter's antenna could be a thousandth of a wavelength. Witness the dipole's radiation resistance as a function of antenna length $\ell$: it is proportional to $\ell^2/\lambda^2$, so, for a given antenna current, the radiated power is proportional to $\ell^4/\lambda^4$ (this is related to the Rayleigh scattering formula) and so small antennas, like narrow slits, radiate very little power relative to the energy stored in their evanescent, so-called "near" fields.
Let's first look at this through scalar theory, i.e. the theory of a scalar field fulfilling the Helmholtz equation $(\nabla^2 + k^2)\psi = 0$ as do all six Cartesian components of the electromagnetic field $(\vec{E},\,\vec{B})$ as well as do the four Cartesian components of the Lorentz gauged potential four-vector $(\vec{A},\,\phi)$, when the field is monochromatic. As I discuss in several other of my answers (see here, here and here) the algorithm for calculating the scalar field on any transverse plane (of the form $z=const$) beyond the slit in terms of that on the plane of the slit ($z=0$) is (here we assume the plane waves only have positive $k_z>0$ wavevector $x$-components, so they are running left to right as they will be if a laser beam is screened by a very small slit:
$$\begin{array}{lcl}\psi(x,y,z) &=& \frac{1}{2\pi}\int_{\mathbb{R}^2} \left[\exp\left(i \left(k_x x + k_y y\right)\right) \exp\left(i \sqrt{k^2 - k_x^2-k_y^2} z\right)\,\Psi(k_x,k_y)\right]{\rm d} k_x {\rm d} k_y\\ \Psi(k_x,k_y)&=&\frac{1}{2\pi}\int_{\mathbb{R}^2} \exp\left(-i \left(k_x u + k_y v\right)\right)\,\psi(x,y,0)\,{\rm d} u\, {\rm d} v\end{array}$$
To understand this, let's put carefully into words the algorithmic steps encoded in these two equations:
  1. Take the Fourier transform of the scalar field over a transverse plane to express it as a superposition of scalar plane waves $\psi_{k_x,k_y}(x,y,0) = \exp\left(i \left(k_x x + k_y y\right)\right)$ with superposition weights $\Psi(k_x,k_y)$;
  2. Note that plane waves propagating in the $+z$ direction fulfilling the Helmholtz equation vary as $\psi_{k_x,k_y}(x,y,z) = \exp\left(i \left(k_x x + k_y y\right)\right) \exp\left(i \sqrt{k^2 - k_x^2-k_y^2} z\right)$;
  3. Propagate each such plane wave from the $z=0$ plane to the general $z$ plane using the plane wave solution noted in step 2;
  4. Inverse Fourier transform the propagated waves to reassemble the field at the general $z$ plane.
So here is the complete description of diffraction from one transverse plane to another. To analyse your slit, you would put $\psi(x,y,0) = 1$ inside the slit and $0$ outside and then put this function into the algorithm above.
When your slit is very narrow - a small fraction of a wavelength, the Fourier transform $\Psi(k_x,\,k_y)$:
$$\Psi(k_x,\,k_y) = \frac{\sin(k_x\,W_x) \sin(k_y W_y)}{2\,\pi\,k_x\,k_y}$$
where $W_x,\,W_y \ll \lambda$ are the $x$- and $y$-direction slit widths (if we have a rectangular hole) has most of its spectrum in spatial frequency regions where $k_x,\,k_y > k$. These are evanescent waves: their $z$ wavenumbers are $k_z = \sqrt{k^2-k_x^2-k_y^2} = i\, \sqrt{k_x^2+k_y^2-k^2}$ so that the plane waves vary like $\exp(-z\,\sqrt{k_x^2+k_y^2-k^2})$, so they are extremely swiftly attenuated with increasing $z$. So when we put the Fourier transform $\Psi(k_x,\,k_y)$ into the above algorithm for $z>0$, the evanescent components are effectively nulled in the $\exp\left(i \left(k-\sqrt{k^2 - k_x^2-k_y^2}\right) z\right)\,\Psi(k_x,k_y)$ term. We are thus left with, in the far field:
$$\begin{array}{lcl}\psi(x,y,z) &=& \frac{\Psi(0,0)}{2\pi}\int_{\mathbb{D}} \exp\left(i \left(k_x x + k_y y\right)\right) \exp\left(i \sqrt{k^2 - k_x^2-k_y^2} z\right){\rm d} k_x {\rm d} k_y \\ &=& \frac{A}{4\pi^2}\int_{\mathbb{D}} \exp\left(i \left(k_x x + k_y y\right)\right) \exp\left(i \sqrt{k^2 - k_x^2-k_y^2} z\right){\rm d} k_x {\rm d} k_y\end{array}$$
where
$$\mathbb{D} = \left\{(k_x,\,k_y):\,k_x^2 + k_y^2\leq k^2\right\}$$
and $A$ is the area of the slit hole. We can find the field from any slit hole as a linear superposition of rectangular holes, so the last form of the equation holds for any slit hole. We further simplify the expression by transforming the transverse wavevector components to polar form:
$$\begin{array}{lcl}\psi(x,y,z) &=& \frac{A}{2\pi} \int\limits_0^k\,u\,J_0(r\,u) \exp(i\,\sqrt{k^2-u^2} z)\,{\rm d} u \\&=& \frac{A}{2\pi} \int\limits_0^k\,u\,J_0(r\,\sqrt{k^2-u^2}) \,e^{i\,u\,z}\,{\rm d} u\end{array}$$
where $r = \sqrt{x^2+y^2}$. This is a hard integral to get a grip on: it has no closed form and both $J_0(u\,r)$ and $\exp(i\,\sqrt{k^2-u^2} z)$ are highly oscillatory when $r$ and $z$ are many wavelengths. But it most decidedly is nonzero: note that the power transmitted varies like $A^2$, i.e. with the fourth power of the slit width. So we see the Rayleigh scattering and farfield dipole antenna functional dependence again.
Not only is the transmission of the radiative diffractive field inefficient, the field must tunnel through a hole of significant axial length (the thickness of the screen) but of much less than a wavelength in width. A round hole supports modes of the form:
$$e^{-\sqrt{\frac{\omega_{\nu,j} ^2}{R^2}-k^2} z} J_\nu\left(\omega_{\nu\,j} \frac{r}{R}\right)\cos(\nu\theta + \delta)$$
where $\omega_{\nu,j}$ is the $j^{th}$ zero of the $\nu^{th}$ order, first kind Bessel function. These are highly evanscent and their amplitude dwindles exponentially with screen thickness.
The vector theory is more complicated, but like the above in flavour. The only difference is that a wave is reflected from the input to the slit to match boundary conditions.
Selene Routley
  • 90,184
  • 198
  • 428
Suppose the flux of the incoming light is a given constant. If the slit is too small, very few photons will ever be lucky enough to encounter the opening. It's a statistics problem: there is 0 chance that any photon can pass through an infinitely small slit.
Before you get to an infinitely small slit, there is another limit. When the slit width is similar to the interatomic distance (around a nanometer), then some electrons of the material from one side of the slit can circulate to the other side. This 'sea' of electrons may close the gap, so that no light can pass through.
fffred
  • 4,296
  • 23
  • 45
