Red colour bares 430-480THz and Violet bares 670-750THz according to Wikipedia.
What frequencies are the colours between red and violet? Will they be higher than red? or lower than violet?
What physically properties do opposite colours carry? Cyan is the opposite colour of red; yellow is the opposite colour of blue; green is the opposite colour of magenta. Can it be expressed mathematically?
The colors "wrap around" solely due to the way human eyes perceive color. Magenta, for instance, is actually both of red and blue wavelengths together that our eyes perceive as "a" color. If you look at magenta light through a spectrometer, however, you'll see that it's actually composed of two different wavelengths and therefore it has no single wavelength. It could probably be best expressed using a mathematical model of the receptors of the eye, such as described in this paper titled "A photon accurate model for the human eye" by Micheal Deering.
Edward
  • 1,294
  • 20
The first thing to realize is this has more to do with how our eyes process light than it does with the physics of light. I find it helpful to use sound as a point of comparison. If you consider light of a single frequency, then there is a spectrum ranging from red at the longest visible wavelengths to violet at the shortest. This is analogous to a lower note going up to a higher note. So far, no circle, just a line segment.
But you can mix light of two different frequencies. And this is where the difference between vision and hearing comes into play. If we hear two different frequencies of sound, we actually perceive it as two different pitches playing at the same time. The reason is that the ear has a huge number of sensors (little fibers in your inner ear) tuned to respond to different frequencies. If you play a middle A and a middle C on the piano at the same time, the hair cells tuned to the lower note and higher note will both respond strongly, but there will be a whole range of hair cells tuned to intermediate frequencies that respond more weakly. So the brain knows that it can’t possibly be a single pure frequency because there’s no way a single frequency could excite both the “middle A hair cells” and the “middle C hair cells” strongly without exciting the “middle B hair cells” even more strongly.
But the eye has a different mission. It puts a lot more work in telling where light is coming from than what the exact combination of frequencies is. So, rather than having sensors finely tuned to a huge range of frequencies, it has sensors (the cone cells) tuned to just three different frequencies. They are called S, M, and L cells, for Short, Medium, and Long wavelength, and the L cells actually peak in the yellow part of the spectrum. But I'm going to call them Blue, Green, and Red since those are the colors we use when we want to stimulate them. See this image from Wikipedia:
Graph resembling three overlapping peaks on a spectrum background; public domain image
Because of the small number of kinds of sensors, you can't distinguish a mixture of blue and green from a pure cyan beam of light, and you can't tell certain different mixtures of green and red from orange and yellow. So we just see a linear spectrum even if sometimes we are seeing "chords" (to use the sound analogy) of mixed light.
But purple/magenta are different. If you mix red and blue without green, you can tell it's not a pure wavelength somewhere between blue and red, because the green intensity is missing. So mixtures of blue and red connect the two ends of the spectrum, making a circle.
Now there's a wrinkle to this, because violet, which is the shortest visible wavelength at all, looks like purple or magenta. I try to give my best understanding, as an amateur, for why that is on Quora (and some of the above text is repeated from that answer). But that doesn't really matter for this question. As long as you have just three color sensors sampling different parts of the spectrum, then you are going to get a triangle of combinations where two sensors have different weights and the other is at zero. When you have all three nonzero, the perception tends to be of a more pastel version (or a muddier version if the total intensity is low) of one of the colors on the boundary of the triangle, rather than something completely different.
Mark Foskey
  • 3,965
Color is a sense perception of light, dependent on the cells of the retina of our eyes.
Light is an electromagnetic wave which can be of single frequency or a mixture of very many frequencies:
This is the electromagnetic spectrum , and the part of it that is visible when a single frequency hits our eye give the color as we perceive it.
em spectrum
Color perception from a mixture of electromagnetic frequencies is another story. One can make full color photographs just using two frequencies, and three can give the whole palette of painters.
perceived color
This image (when viewed in full size, 1000 pixels wide) contains 1 million pixels, each of a different color. The human eye can distinguish about 10 million different colors.[18]
Single frequencies display color, but a color corresponds to many frequencies in combination with the response of the eye.
anna v
  • 236,935
