57
A star's collapse can be halted by the degeneracy pressure of electrons or neutrons due to the Pauli exclusion principle. In extreme relativistic conditions, a star will continue to collapse regardless of the degeneracy pressure to form a black hole. Does this violate the Pauli exclusion principle? If so, are theorists ok with that? And if it doesn't violate the Pauli exclusion principle, why not?
kd88
  • 1,937
I don't have a very satisfactory description of the microscopic picture, but let me share my thoughts.
The Pauli exclusion doesn't quite say that fermions can't be squeezed together in space. It says that two fermions can't share the same quantum state (spin included). A black hole has an enormous amount of entropy (proportional to its area, from the famous Bekenstein-Hawking formula $S = \frac{A}{4}$) and hence, its state count is $\sim e^A$.
Now, this might not seem like a big deal since usual matter has entropy proportional to volume. However, volume of such collections is also proportional to the mass. This means that a counting of the number of states goes as $e^M$
For a black hole, it's Schwarzschild radius is proportional to the mass, hence $A \sim M^2$. So, the number of states scales as $e^{M^2}$ which is much much more than ordinary matter, especially if the mass is "not small". So there seem to be a lot of quantum states into which one can shove the fermions.
So it seems like the fermions should have an easier time in a black hole than in (say) a neutron star.
Siva
  • 6,204
18
All the known laws of physics, including the exclusion principle, are believed to be valid at all times during the collapse, up until the matter that you're talking is just about to hit the singularity. ("Just about to hit" may mean when the density reaches the Planck density, so that quantum gravity effects become important, or it may be a little earlier, if there is other physics beyond the standard model that we don't know about.)
Note that just because an event horizon has formed, and some matter has fallen past the event horizon, that doesn't mean that the conditions experienced by that matter are extreme. They needn't be extreme at all. The equivalence principle says that the laws of physics are always locally the same, because spacetime can always locally be approximated as flat, so that special relativity applies. Actually the conditions at the formation of the event horizon are pretty solidly within the range of conditions (temperature, pressure) that can be described by the standard model of particle physics.
Degenerate matter is simply matter in a state where the degeneracy pressure is significant. In a white dwarf or neutron star, for example, the degeneracy pressure happens to be in equilibrium with gravity. The matter can be compressed further without violating the exclusion principle. The exclusion principle essentially has the effect of imposing a maximum wavelength on each particle, which goes roughly like $\lambda \sim (V/N)^{1/3}$, where $V$ is the total volume and $N$ is the number of identical fermions. If $V$ gets smaller, you get a smaller wavelength, therefore bigger momenta and higher pressure.
In stars that aren't massive enough to form black holes, you reach a point where this higher pressure gets big enough to give an equilibrium with gravity. If the star is more massive, so that we are going to form a black hole, then we just don't reach such an equilibrium. The wavelengths of the fermions simply get very short, and their momenta very high, as we approach the formation of the singularity.
We don't try to say anything about the singularity itself using the presently known laws of physics. In pure classical general relativity, the singularity is not even considered to be part of the spacetime.
Cham
  • 8,015
The short answers are "yes" and "yes". Recall that we are talking about what happens inside the event horizon ...
Perhaps the density of states diverges as volume decreases. However iirc most thinking is around the idea that there is a quark degeneracy limit that has to be overcome like the neutron degeneracy limit.
i.e. those people speculating some process that combines quarks into some boson can pat themselves on the back.
The bottom line is that we don't know enough about how matter/energy behaves in such extreme conditions to be able to do more than speculate.
Also see: http://www.physicsforums.com/showthread.php?t=600360
-4
In actuality, there is no such thing as this so called singularity...
It's a convenient mathematical invention to represent something of which we understand very little.
Although quantum physics can often seem to be antithetical to common sense, I prefer to apply some wherever I can.
Having said that, there will turn out to be no infinite densities or pressures or anything of the sort.
The reason light can't escape will have nothing to do with gravity..
It can't escape BECAUSE THERE IS NO LIGHT...
I believe that once in falling matter crosses the event horizon and gets past the planc scale...
IT ESSENTIALLY TURNS INSIDE OUT AND IS THEN A HIGHER DIMENSIONAL OBJECT.
IT doesn't occupy the same space therefore no exclusion principle is broken and would also completely explain our little dark matter and energy problem...
It is in multiple dimensions that aren't separated by space or time and therefore gives the universe a
METHOD TO RE-COLLAPSE IN ON ITSELF AFTER ALL MATTER HAS BEEN EATEN BY BLACK HOLES (some google years from now)
elfeiin
  • 128
