Possible Duplicate:
Why would Antimatter behave differently via Gravity?
Regarding the following statement in this article:
Most important of these is whether ordinary gravity attracts or repels antimatter. In other words, does antihydrogen fall up or down?
Is this a seriously considered hypothesis? What would be the consequences on general relativity?
If this is seriously studied, can you point to some not-too-cryptic studies on the (anti ;-)matter?
Sklivvz
  • 13,829
EDIT: fixed thought experiment.
If antimatter anti-gravitates, it would be possible to build a perpetual motion machine:
1) Start with a zero-net momentum pair of photons. Have them collide, and make a particle/antiparticle pair. These can be moved around arbitrarily with zero net work, since any gravitational force on the particle will be equal and opposite to the force on the antiparticle.
2) raise them to an arbitrary height. Let them collide, producing a massive particle that is its own antiparticle, say a Higgs.
3) let this particle fall. It gains energy
4) let the particle decay upon falling. it now has the rest energy of the particle/antiparticle pair (equal to the energy of the two photons), plus any gravitational potential from falling.
5) reflect the two photons that are the decay product on antipodal mirrors attached by a wire and suspended from the ceiling. No net momentum or energy is transferred to this mirror system, and the photons can be freely merged again to repeat the process.
I can't guarantee the authenticity of the article. But it seems to me quite bizarre since I fail to see how something (even antimatter) can behave differently than matter in a gravitational field without violating the equivalence principle.
A positron for example is a hole in the Dirac sea and it has the same mass as of the electron and behaves exactly similar to an electron in a gravitational field.
The only repulsive gravity that exists in GR is the cosmological constant in the Einstein's equations which is in no way related to antimatter.
The only problem with this is that antimatter has the same mass as its matter counterpart. So this means that is effected the same way by gravity as normal matter.
Xplane
  • 421
