$\alpha_L = \frac{1}{a}\frac{da}{dT}$
I know error in $a$, i.e., $da$
I need to find out $d\alpha$ from data of $da$.
$d\alpha_L = -\frac{1}{a^2}\frac{da}{dT}da$
Is this correct?
Note:
$\alpha_L$ = Linear thermal expansivity
$a$ = Lattice constant
Is this correct?
Note:
You are confusing yourself with two different uses of $da$, it would be better to make the error $\delta a$ Then if you consider $\frac {da}{dT}$ to be a constant you will be correct.
