If I understand right the Z boson and photon are both a mix of the same two bosons, the W_3 and the B boson of weak isospin. If the Z boson and photon are both made of the same bosons, then they should both react with the same particles, but with the Z boson only working at short distances because of the higgs. But this is wrong because photons only effact particles with charge, but Z bosons effects neutral particles as well.
Where in my reasoning am I wrong?
Their differences (and reasons):
$\bullet$ (1) $Z$ boson is massive and photon is massless.
  • As you have said $Z$ boson is massive(~91 Gev) due to Higgs mechanism, but photon stays in the unbroken U(1) sector.
$\bullet$ (2) $Z$ boson has gauge coupling differently from the photon. Look at the covariant derivative (see Peskin&Shroeder Intro to QFT chap 22):
The standard model electroweak symmetry breaking is
$$\text{SU(2) $\times$ U(1)$_Y$ $\to$ U(1)$_{em}$}$$ with U(1)$_Y$ renders hyper U(1) charge $Y$, which is different from the electromagnetic charge U(1)$_{em}$ charge $$e=\frac{gg'}{\sqrt{g^2+g'^2}}.$$ Notice that the photon of U(1)$_{em}$ has the U(1) generator by $T^3+Y$ (mixing between SU(2) and U(1)$_{Y}$). Similarly, $Z$ boson has a generator (mixing between SU(2) and U(1)$_{Y}$) by $g^2T^3+g'^2Y$. However, the couplings of two bosons are different.
As you said, $Z$ boson has coupling to neutral particle (neutral under U(1)$_{em}$), but the photon does not. The reason is, "being charged" under unbroken U(1)$_{em}$ (i.e. $T^3+Y$) is not the same as "being charged" under one of three generators of broken SU(2) (i.e.$g^2T^3+g'^2Y$).
$\bullet$ (3) Feynman rules are analogues to each other, but with different couplings:enter image description here
source for Feynman rules: Griffiths: Intro to elementary particles.
wonderich
  • 8,086
