I read from Mandl & Shaw that when quantizing massless vector particles such as photons in Lorentz gauge, there are 4 linearly independent polarization vectors (2 of them being able to "gauged away"), while when quantizing massive vector particles such as W bosons, there are only 3 linearly independent space-like polarization vectors. It also says that when W and Z gauge bosons "eat" the Goldstone bosons from Higgs field, they become massive and acquire longitudinal polarization. So apparently there is some rule that says massive vector particles have longitudinal polarization, while massless particles don't. Why is that? From what principle is it derived? Their Euler-Lagrangian equations are essentially the same (both look like Klein-Gordon equation), just one of them has $m=0$. Is it the case that when $m=0$, it has four linearly-independent solutions while only three when $m\neq0$ ?
Massive vector may have longitudinal or transversal polarization. This is disscused in almost every QFT book, like Weinberg vol. 1.
Anyway, an intuitive explanation is that if $m=0$, logitudinal polarization is not possible since the particle would travel at $v<c$ or $v>c$ (due tu vibrations in it's direction's motion). While in the massive case, $v<c$ and longitudinal polarization is possible.
Mathematicaly, this can be explained in the context of Wigner's classification.
If we define $W_\mu=\frac{1}{2}\epsilon_{\mu\nu\rho\sigma}P^\nu M^{\rho\sigma}$ and $P_\mu=i\partial_\mu$. We can classify any particle in function of the eigenvalues of $W_\mu W^\mu $ and $P_\mu P^\mu $ .
In the massive case $P_\mu P^\mu >0$, the eigenvalues of $W_\mu W^\mu$ are $-m^2 s(s+1)$ and the spin $s$ can take $n/2$ values.
But if $m=0$, the eigenvalues of $W_\mu W^\mu$ are zero, since $P^\mu W_\mu=0$. Which means that $P$ and $W$ are proportional, where the proportionality constant is the helicity (polarization).
- 10,659
- 12,675
- 7
- 60
- 102
I know no better answer that the one from jinawee (but would be interested to learn about). The trouble with the "simple" answer (ashpool) is that the numerology 4 -> 3 (Proca) -> 2 (Gauge invariance) leaves the student (it did in my case, years ago) with the idea that only for spin=1 a massless particle has 2 degrees of freedom, while Wigner's classification shows that this is a feature of any massless particle (plus parity symmetry).
- 21
The solution of the Proca equation for massive spin-1 particles automatically satisfies Lorentz condition, eliminating one degree of freedom from the 4. This turns the polarization vector into space-like vector with three components.
For massless vector particles, gauge invariance eliminates one more degree of freedom, leaving only two polarization states. This fact for massless particles can also be explained intuitively by the fact that it has no 3-dimensional rest frame -- only 2 helicity states. Apparently Wigner proved this mathematically.
- 672
- 5
- 15
