In my dynamics notes I have written the following: $$\frac{d\vec{p}_A}{dt}= \sum\vec{AC_i}\times m\vec{a_{ci}} + \sum \frac{dR_i}{dt}\left\{{I^{(i)}_{ci}}{\omega}^{(i)}_{ci}\right\}+\sum R\left\{{I^{(i)}_{ci}}\frac{d{\omega}^{(i)}_{ci}}{dt}\right\}$$ where $A$ is a random point, $C_i$ the center of mass of object $i$, $\left\{{I^{(i)}_{ci}}{\omega}^{(i)}_{ci}\right\}$ (an admittedly strange notation for) the resulting vector from $I_{i}\vec{\omega_{ci}}$ if $I_{i}$ is a diagonal matrix and $R_i$ a matrix that projects object $i$ to its principal axes of inertia. I am, however, incapable of finding my derivation of this formula.
Is this formula always correct? And also, -if correct- could $\frac{dR_i}{dt}$ be replace with $\vec{\omega_i}\times R_i$?
First off, yes $\frac{dR_i}{dt} = \vec{\omega_i}\times R_i$ if $R_i$ is the local $\rightarrow$ global 3×3 rotation matrix of the i-th body. Meaning that the columns of $R_i$ correspond to the global coordinates of the local $\hat{x}, \hat{y}, \hat{z}$ axes.
I will drop the $i$ subscripts and the $\sum$ and derive the above for one body.
Angular momentum at an arbitrary point A not on the center of mass C is defined as
$$ \vec{p}_A = \vec{p}_C + \vec{r}_{AC} \times \vec{L} = \bar{I} \vec\omega + \vec{r}_{AC} \times m \vec{v}_C $$ where $\vec{L}$ is linear momentum vector, $\vec{\omega} = R\,\vec{\omega}_c$ the angular speed in global coordinates, $\bar{I} = R\,I_c\,R^\top$ the 3×3 inertia tensor in world coordinates, and $\vec{v}_C$ the velocity of the center of mass in world coordinates.
(see https://physics.stackexchange.com/a/91246/392 for more details)
Putting it all together yields
$$ \begin{aligned} \vec{p}_A & = (R\,I_c\,R^\top) R\,\vec{\omega}_c + \vec{r}_{AC} \times m \vec{v}_C \\ & = R\, I_c \vec{\omega}_c + \vec{r}_{AC} \times m \vec{v}_C \end{aligned}$$
Which you can differentiate, but I cannot do unless you explain in details which coordinate system each quantity is defined as. It seems that rotational terms are in local coordinates, and linear terms in world.
John Alexiou
  • 40,139
