I'm currently building a custom desk. In this desk I will also build-in a small part with a custom electronic panel to provide power to USB devices.
As my gaming pc generates a lot of heat and the panel will generate some too, I was thinking about doing something with this heat. I read another post on this physics part of stackExchange where they say it isn't efficient and you would need a alot of cold air supply.
As I live in Belgium, most time of the year there is enough of cold air, just outside of my window. Another thing is, it doesn't have to be super efficient. If I could just generate enough current to give power to one or more USB connectors or store it in a battery, I would be happy.
Is it possible to create enough energy for my USB, if I got a hot air flow of 50°C and a cold air reservoir of 0-10°C? Follow up question, is it practically possible?
USB works at 5 Volt at a current from 0.5 to 5 Amps.
Other (possible?) options I found was using thermocells and thermocouples.
Ok, never mind. After checking some videos of homemade thermo electric generators, it's obvious my situation will never provide enough current and voltage for my USB. One created a voltage of arround 0.5V with a flame but with hardly enough current. Maybe I will create one for fun to check if it could light up some LEDS. Thanks!
