20
This questions has been asked all over the net (here included) but I can't find a satisfactory answer or discussion. Some say it does not radiate if the acceleration is caused by a uniform gravity field. Some even say that it radiates in linear accelerators because of our imperfect technology. All this comes from university member (at least they claim to be). My head is spinning. I always thought (from CED) that any kind of acceleration causes the charge to radiate and loose energy, not that I say that this is the case, but the equivalence principle of relativity never crossed my mind while thinking about this puzzle. Today it did.
Can someone here give some good, kind of fresh, references (no ArXiV please!) or alternatively, try to explain better than what others have done?
This is an experimentalist's answer and yes, accelerated charged particles either in stable circular orbits or in linear acceleration do radiate.
Classically, any charged particle which moves in a curved path or is accelerated in a straight-line path will emit electromagnetic radiation. Various names are given to this radiation in different contexts. For example, when is occurs upon electron impact with a solid metal target in an x-ray tube, it is called "brehmsstrahlung" radiation.
So it is an experimental fact well known to particle physicists.
There exist classical electromagnetic calculations of this radiation, as seen in the link provided. The fact that the electrons did not fall into the nucleons from the loss of radiation was what prompted the quantized Bohr model and led to the discovery of quantum mechanics.
The controversy seems to be in introducing special relativity concepts for the motion of the charge and the observer, which I cannot really follow . I found this review though with references therein.
Edit after comments:
I would like to add to this "principle of equivalency" navel gazing that there also exists something called conservation of energy in a system. If a particle is radiating and it is not dissolving like the ISON comet recently, the energy in a system must come from somewhere. An elementary particle is intact through all the special relativity transformations, so the energy must be supplied by the potentials as perceived by the observer in whatever system he is set up in, as seen in this this answer to a similar question.
In the case of a charge at rest ( comoving system of observer and charge) there are no potentials to supply the energy. Approaching the situation differentially with acceleration going to zero, the radiated wavelength get a longer and longer wavelength, the energy taken from the acceleration of the observer, and when reaching at rest they become the static electric field .
Now it is well known that when reaching limits for electromagnetism and apparent paradoxes, these are resolved by going to the quantum mechanical framework. I suspect that until we get a unified quantized theory for general relativity and the three other forces the subject will remain at this level of a discrepancy/explanation as far as the equivalence principle is concerned.
anna v
  • 236,935
A charge dropped in a uniform gravitational field will radiate, despite the equivalence principle suggesting that it won't. This is because the boundary conditions on the fields (asymptotic behavior for large distances) in the case of a uniform gravitational field are different from the case of a freely floating charge.
Count Iblis
  • 10,396
  • 25
  • 49
Do accelerated charges radiate or not?
It depends. A falling charged particle doesn't radiate. Nor does a charged particle accelerating because of a static electric field. Cyclotron radiation and synchrotron radiation are associated with acceleration due to a magnetic field.
A falling charge does not radiate. It doesn't matter whether the gravitational field is uniform. The particle is in free fall, and the principle of equivalence says standing on the ground is like accelerating through space. But note that a charged particle sitting on the ground doesn't radiate either. It only radiates when it stops falling because it hits the ground. Compare this with what happens to the electron when it's attracted to the proton to form a hydrogen atom.
Can you give me a reference for that? See this: "While it is possible to accelerate charged particles using electrostatic fields, like in a Cockcroft-Walton voltage multiplier, this method has limits given by electrical breakdown at high voltages. Furthermore, due to electrostatic fields being conservative, the maximum voltage limits the kinetic energy that is applicable to the particles. To circumvent this problem, linear particle accelerators operate using time-varying fields..."
All this comes from university member (at least they claim to be). My head is spinning. I always thought (from CED) that any kind of acceleration causes the charge to radiate and lose energy
Not any kind, and not gravitational falling-down acceleration. That converts potential energy, which is mass-energy, which is internal kinetic energy, into external kinetic energy. It doesn't radiate it away whilst the particle is falling. In similar vein falling down doesn't hurt a man. It's the sudden cessation of falling down that causes his teeth to radiate across the pavement.
It shouldn't be a puzzle. IMHO it's only a puzzle because somebody has oversimplified some teaching. Or maybe confused two different fields of physics.
I'm not sure I can. Have a look at this. And who's telling you that falling charged particles radiate. They don't. If they did Einstein's general relativity would be wrong, and it isn't. Instead it's one of the best-tested theories we've got. See The Confrontation between General Relativity and Experiment by Clifford M Will.
John Duffield
  • 11,381
