The measurement of the WMAP satellite resulted a planar geometry of the universe with a 0.4% uncertainity (http://en.wikipedia.org/wiki/Shape_of_the_universe).
If there is a little deviation from the measured zero curvature, I think it could give a lower limit to the size of the universe (in case of positive curveture and spherical geometry). How big is it? How could it be calculated?
Pulsar
  • 14,970
peterh
  • 8,872
From the Friedmann equations, you can derive that $$ \dot{R}^2 - \frac{8\pi}{3}G\rho R^2 = -k c^2, $$ where $\rho$ is the total density of the universe and $k$ is a constant that determines the shape of the universe: $k=-1,0,1$ for an open, flat and closed universe, respectively. If the universe is a hypersphere ($k=1$), then $R$ can be thought of as its 'radius'.
Because the right-hand side is a constant, it is also equal to the present-day values $$ \dot{R}_0^2 - \frac{8\pi}{3}G\rho_0 R_0^2 = -k c^2, $$ or $$ \frac{\dot{R}_0^2}{R_0^2} - \frac{8\pi}{3}G\rho_0 = -\frac{kc^2}{R_0^2}, $$ and, introducing the Hubble constant $H_0=\dot{R}_0/R_0$, we get $$ H_0^2 - \frac{8\pi}{3}G\rho_0 = -\frac{kc^2}{R_0^2}. $$ If $k=0$, we have a flat universe, and the corresponding density equals the so-called critical density $$ \rho_{c,0} = \frac{3H_0^2}{8\pi G}. $$ The general case can thus be written in the form $$ H_0^2\left(1 - \frac{\rho_0}{\rho_{c,0}}\right) = -\frac{kc^2}{R_0^2}. $$ Finally, the factor between brackets is denoted as $\Omega_{K,0}$, so that $$ H_0^2\,\Omega_{K,0} = -\frac{kc^2}{R_0^2}. $$ In case of a universe with positive curvature, $k=1$ and $\Omega_{K,0}$ is negative, so that $$ R_0 = \frac{c}{H_0\sqrt{-\Omega_{K,0}}}. $$ The nine-year WMAP value for $\Omega_{K,0}$ is (see the last table on the wiki page) $$ \begin{align} \Omega_{K,0} &= -0.037^{+0.044}_{-0.042}\qquad&&\text{(WMAP only)},\\ &= - 0.0027^{+0.0039}_{-0.0038}\qquad&&\text{(WMAP + other obs.)}, \end{align} $$ and $H_0 = 70\;\text{km}\,\text{s}^{-1}\,\text{Mpc}^{-1}$. So we find $$ \begin{align} R_0 &\approx 22.3\;\text{Gpc}\approx 72.7\;\text{billion ly}\qquad&&(\text{for $\Omega_{K,0} = -0.037$}),\\ R_0&\approx 82.5\;\text{Gpc}\approx 269\;\text{billion ly}\qquad&&(\text{for $\Omega_{K,0} = -0.0027$}). \end{align} $$ This can be interpreted as the radius of the universe if it is a hypersphere, although the topology of the universe could be more complicated. The latest Plank results put even tighter constraints on the curvature of the universe (see page 40 in this paper).
Pulsar
  • 14,970
