64
Famously, the path integral of quantum field theory is related to the partition function of statistical mechanics via a Wick rotation and there is therefore a formal analogy between the two. I have a few questions about the relation between the two objects.
  1. Loop diagrams in quantum field theory have a nice interpretation in terms of virtual particles. What is the interpretation of loops in statistical mechanics?
  2. Does the relation between the two objects imply that for every quantum mechanical phenomenon there's a corresponding statistical mechanics phenomenon and vice versa? If not, where does the analogy fail?
  3. If so, what would be the phenomena analogous to the Aharonov-Bohm (AB) effect? It's hard for me to see the analog for any quantum effect that depends on phase interference like the AB effect.
user26866
  • 3,582
  • 26
  • 37
I think it will depend the kind of statistical mechanics. For classical statistical mechanics, there is no time, so it is really hard to imagine a nice physical picture of the propagation of something. But nevertheless we still talk of loops as propagating "particles" (we give the "momenta", for instance, which is conserved, etc.). Interestingly, renormalization (a la Wilson) is easier to understand on a physical ground in statistical physics, where the coarse graining has a very nice interpretation.
On the other hand, in quantum statistical physics, the analogy is bit more direct, though time is still imaginary, so nothing really propagates. But in some sense, we still sum over all the possibilities (in a static sense, though). In this case, AB effect will give the quantization of the flux, or the Quantum Hall Effect.
Anyway, concerning the first question, keep in mind that loops, Feynman diagrams and virtual particles are artifacts of pertubation theory, and therefore have no real physical interpretation.
Adam
  • 12,192
In my naive view, this is merely a mathematical trick that should not be taken too seriously in term of physical interpretation.
After all, a "Wick rotation" applied to the Schrodinger equation yields a diffusion equation. This is helpful for some mathematical problems but the physics it describes is very very different from quantum mechanics; not even mentioning that one is a wave equation while the other is a Fokker-Planck equation.
Now, because quantum field theory and statistical field theory share the same mathematical structure (i.e. a path integral as a generating functional), they also share useful tools like Green functions, Wick theorem, Feynman diagrams and so on but this more a mathematical coincidence than a deep meaningful analogy between the two, in my opinion...
gatsu
  • 7,550
[By statistical mechanics I mean classical statistical mechanics throughout this answer. If you are curious to think about the complications added with making the statistical side of the story quantum mechanical, that sounds like a very good exercise. For clarification look at Chap. 3 of "Conformal Field Theory" by Di Francesco et al.]
The analogy between "Euclidean quantum field theories" and "equilibrium statistical mechanics near second order phase transitions" is exact, once you identify $\hbar$ (on the quantum side) with $1/\beta$ (on the statistical side). Being careful with the terms Euclidean and equilibrium is important to avoid misguided analogies. The proximity to a second order phase transition guarantees that (the continuum limit of the underlying statistical system approximates it well, and thus) the statistical mechanics can be well approximated by statistical `field theory'.
1) Roughly speaking, in real time quantum field theory, every intermediate stage happens with a probability proportional to $e^{iS/\hbar}$. Often you interpret those intermediate stages as "virtual particles". In Euclidean (or imaginary time) quantum field theory, there is no "intermediate" stage, so the right interpretation is (not in terms of virtual particles, but) that all possible classical configurations contribute to the partition function with a probability proportional to $e^{-S/\hbar}$. Now to connect this Euclidean QFT situation with one in equilibrium statistical mechanics near a 2nd order phase transition, one only needs to specify in what sense "all possible classical configurations contribute to the statistical partition function with a probability proportional to $e^{-\beta S}$". The sense in which the above statement is true in equilibrium statistical mechanics is of course, the Ergodic sense.
In sum, the answer to your first question is that i) the virtual particle interpretation does not apply to Euclidean QFT (which, unlike real time QFT, is analogous to equilibrium statistical mechanics near second order phase transitions), ii) in both Euclidean QFT and equilibrium statistical mechanics, every allowed classical configuration contributes to the partition function; it is just that in Euclidean QFT this has a fundamentally probabilistic interpretation, whereas in equilibrium statistical mechanics it has a statistical interpretation supported by the Ergodic theorem.
2) Yes. In fact, every Euclidean quantum field theory can be regarded as describing an equilibrium statistical physics system near a 2nd order phase transition. The term Statistical Field Theory is applied whenever the field theory is interpreted as describing some statistical system.
3) There is no Aharonov-Bohm effect (in the sense of electrons propagating and interfering with each other) in Euclidean QFT. This is a confusion similar to the one with "virtual particles" which is due to not keeping the word Euclidean in mind; there is no propagation in imaginary time QFT. Also on the equilibrium statistical mechanics side, there is no such a thing. However, if you are looking for manifestations of non-trivial gauge bundles, you can find such manifestations on both sides by looking at Wilson loops circulating around solenoids installed in your quantum or statistical system.
I will have to disagree with some of the answers posted in this question.
Firstly, this involves a matter of interpretation of the quantum formalism (eg a prevailing interpretation, the Copenhagen one).
Although such interpretation (which I find wanting) may seem prevailing (and indeed it might be), it is not because it necessarily offers a better or more clear understanding of quantum mechanics (indeed the known R. Feynman quote might be relevant, "no one understands quantum mechanics").
Most physicists just work on a formalism and not enter into any interpretation aspect, although they may find it unsatisfactory.
(sometimes this turns into a "scientific taboo")
So the answers posted that speak of a coincidental resemblance between statistical mechanics and quantum mechanics, actually talk about interpretation.
So a specific interpretation leads to an associated answer.
Leaving aside all this for a minute (my stance is that the connection between quantum mechanics and statistical mechanics, specifically entropy, is very interesting); let's see some other relations between QM and SM:
  1. Planck's constant (and indeed the start of QM) was on a statistical mechanics problem (black-body radiation). Furthermore Planck's constant $h$, was computed using statistical methods.
  2. Wick rotation has a physical meaning, ie. there is one to one correspondence between a "quantum" system and a "statistical" one, The formalism actually reflects this fact
  3. There are theories (more or less sponsored) which derive quantum mechanics as an extension of statistical mechanics (or vice-versa). Eg. Stochastic Mechanics, Generalised Thermodynamics, etc..
  4. Quantum mechanics without complex numbers (and Hilbert spaces) is just Statistical mechanics (and Euclidean spaces). One use of complex numbers is to define a boundary, a closed system, periodic conditions. Since quantum mechanics can represent a SINGLE system (unlike statistical mechanics which represents ENSEMBLES of systems), it all goes back to the double-slit experiment and the interpretation thereof.
  5. There is still the problem of quantum measurement asymmetry (and possible relations to entropy), which lacks an in-depth explanation/interpretation/re-formulation.
UPDATE: in a light-hearted fashion one can say that QM seems to be the SQUARE-ROOT of SM, or mutatis-mutandis SM is the SQUARE of QM
Nikos M.
  • 5,302
