To calculate the calories burned doing 1 squat, wouldn't it simply involve the distance that your center of mass is moving and your weight? I read some other article that said your legs act as levers, so the calculation has to involve that. Then of course you have to come up with the efficiency of your body.
You are on the right track for the minimum energy required. It has to be at least that required to lift the weight over the height change.
However, there are so many other things envolved that this minimum energy per squat won't be a very useful figure, although the legs acting a levers has nothing to do with it. Either way, the body weight is raised, requiring energy. The efficiency of converting food calories into work to raise the body is going to be hard to nail down. Muscles also don't use up energy proportional to energy delivered, even if the efficiency is known. A lot, if not most, of the energy required to activate a muscle is more a function of the force it produces. For example, keeping yourself suspended at half-squat would be quite fatiguing and use up some calories, but isn't actually doing mechanical "work".
While your physics is right, I suspect the answer will be pretty meaningless in a real sense. The best way to determine calories/squat is to measure it. Metabolic activity can be measured reasonably well by measuring oxygen consumption. There are systems that do exactly that, often together with a treadmill to force the body to do a certain amount of biological work. Note that running on a flat surface is actually doing very little physics work.
- 13,084
