This is a pedagogical effort in aid of understanding the Ehrenfest paradox. The Ehrenfest paradox concerns a rigidly rotating relativistic disc. The term paradox does not mean the physics is in any doubt; it means simply that an untrained intuition may lead one astray.
As a way in, consider the following problem:
Q1. $N$ electrons are equispaced around a circular ring of radius $1$ metre as observed in the laboratory (the laboratory is an inertial frame of reference). The ring rotates such that the speed of each electron, relative to the laboratory, is $0.99499\,c$. The proper distance between each electron and its neighbours is $62.8\,$centimetres. How many electrons are there in the ring?
Q2. A solid disc is initially at rest relative to the laboratory. It is then
set in motion by forces which act in such a way that each part of the disc acquires
its new momentum impulsively and simultaneously in the laboratory, with negligible
change of position. Thereafter, centripetal forces (including, but not necessarily
limited to, stresses in the disc) act in such a way that all parts follow circles
in the laboratory frame, centred on the disc's centre, with the same angular
velocity $\omega$. (This kind of motion is called rigid motion because once it
is set up, distances between parts of the moving body are constant in time). What is
the ratio between the circumference and the radius of this rotating disc,
(i) as observed by using standard rods fixed in the laboratory frame?
and
(ii) as observed by attaching standard rods to the disc, and counting the number across a radius and around the circumference?
[As always in relativity, a standard rod is a solid rod with unit proper length, i.e. unit length in its own inertial rest frame, and for an accelerating rod one considers an inertially moving rod whose worldline is tangential to that of some part of the accelerating rod (i.e. they momentarily have the same velocity at some given event), and one takes a limit where the unit of length is small compared to $c^2/a_0$ where $a_0$ is the proper acceleration.]
Q3. The following arguments are commonly applied to the above problem of the rotating disc:
Argument A: When set in motion, the disc suffers Lorentz contraction around the circumference but not along a radius. Consequently the ratio of circumference to radius, as observed in the laboratory, is $2\pi/\gamma$ where $\gamma$ is the Lorentz factor associated with the speed of the rim of disc.
Argument B: When set in motion, the disc acquires its new motion instantaneously in the laboratory, without significant change in position, and therefore the ratio of circumference to radius, observed in the laboratory, does not change: it is $2\pi$ and remains $2\pi$ thereafter.
Which of A or B (or neither) is correct? Your answer should also clarify where any failed argument(s) went wrong.
