This question obviously could have been improved in many ways, and I'd appreciate if you answer it and pinpoint some holes/inconsistencies.
Assume that there is a black hole (or just a very very massive body) in a flat universe which bends the spacetime around it. There is a light source which is on the opposite side of the black hole some distance away from it. If we trace the geodesic of light's travel, then we find some line around the blackhole (not straight, right?).
Could when traveling on the curvature takes less time than making a "detour" on flatter spacetime be described as black hole’s horizon (Fermat's principle of least time)?
Possible mistake I thought: wouldn't each heavy star have a small black dot in the centre, but it's not observed (as traveling at the steepest curvature is longer than just a bit around it); big stars would imitate blackholes (or do they do so inside?)
Research: this post says that Fermat's principle does hold, but my question extends to a question about black hole (/massive body). Can its radius be calculated through some very complicated derivative w.r.t. proper time? :) I appreciate QMechanic's refs, I'll take a look.
