The electron degeneracy pressure (EDP) dominates in White dwarfs, where the electrons are compressed to very high densities. EDP is a purely quantum mechanical effect that arises due to Pauli's exclusion principle - the fact that no two fermions can occupy the same quantum state. It has nothing to do with electrostatic repulsion between electrons, and it is also not a thermal pressure (it exists, and in fact obtains a maximum at, $T=0$). This prevents further gravitational collapse of the star. The expression for the EDP depends on whether the electrons are non-relativistic or ultra-relativistic - as it can be seen that the expressions are independent of the electronic charge and the temperature: \begin{eqnarray} P_e = \begin{cases} \frac{(3\pi^2)^{2/3}}{5}\frac{\hbar^2}{m_e} n_e^{5/3}, & \mbox{if } ~\text{nonrelativistic} \\ \frac{(3\pi^2)^{1/3}}{4} \hbar c \, n_e^{4/3}, & \mbox{if} ~~\text{ultra-relativistic}. \end{cases} \end{eqnarray}
My question is the following.
On top of the EDP, should there not be another source of outward pressure that can potentially counteract the gravitational collapse - namely the electrostatic repulsion between the electrons? Intuitively, one would think that the electrostatic repulsion will prevent the electrons from coming too close to each other, and hence, also act against the inward gravity and help support the star against collapse. Is this effect small for some reason, and if so, why and how small? Can we compare how small the effect is (quantitatively) in comparison to the EDP?
