In this text ELECTRON EMISSION AND CATHODE EMITTANCE the authors give a formula for the velocity distribution of thermally emitted electrons as
The velocity distribution for thermally emitted electrons is obtained from the derivative of Maxwell-Boltzmann particle distribution, $$ \frac{1}{n_e} \frac{dn(v_x)}{dv_x} = \frac{m}{k_b T } v_x \exp \left( \frac{-mv_x^2}{2 k T} \right) $$
Could someone explain how is this derived ? The only other source I could find was an older question (Thermal emission cathode electron velocity distribution) which has all the answers I need except the links no longer work. Any help would be greatly appreciated.
I've worked something out, but I'm not sure if it's right. Here it is, just in case
Electrons can escape only if their velocity in the $ x $-direction is large enough to overcome the work function
$$ v_{x,\text{min}} = \sqrt{\frac{2 W}{m_e}} \tag{1} $$
and after crossing it, their kinetic energy in the $ x $-direction decreases by $ W $
$$ \frac{1}{2} m_e v_x'^2 = \frac{1}{2} m_e v_x^2 - W \tag{2} $$
Now to compute the Richardson-Dushman current, we integrate the velocity distribution inside over all electrons with $ v_x \ge v_{x,\text{min}} $ :
$$ J = \int_{-\infty}^{\infty} \int_{-\infty}^{\infty} \int_{ v_{x,\text{min}} }^{\infty} e v_x n(\vec{v}) dv_x dv_y dv_z \tag{3} $$
and by changing variables using $ v_x' dv_x' = v_x dv_x $ the integral becomes
$$ J = \int_{-\infty}^{\infty} \int_{-\infty}^{\infty} \int_{ 0 }^{\infty} e v_x' n(\vec{v}) dv_x' dv_y dv_z \tag{4} $$
Since current is the same after crossing, we can also write it using the velocity distribution $ n' $ outside
$$ J = \int_{-\infty}^{\infty} \int_{-\infty}^{\infty} \int_{ 0 }^{\infty} e v_x' n'(\vec{v}') dv_x' dv_y dv_z \tag{5} $$
Implying:
$$ n'(\vec{v}') = n(\vec{v}) \tag{6} $$
For high energies, the distribution inside approximates a Maxwell-Boltzmann distribution :
$$ n'(\vec{v}') = \frac{2 m_e^3 }{h^{3}} \exp\left( - \frac{m_e(v_x^2 + v_y^2 + v_z^2)}{2kT} + \frac{\mu}{kT} \right) \tag{7} $$
where we can substitute in (2) to get
$$ n'(\vec{v}') = \frac{2 m_e^3 }{h^{3}} \exp \left( \frac{\mu - W}{k T} \right) \exp\left( - \frac{m_e(v_x'^2 + v_y^2 + v_z^2)}{2kT} \right) \tag{7} $$
