My question is that when we apply a force equal to $F$ to an object and $F$ is greater than $F_{s,\text{max}}$, then it is clear that the object moves. But with what acceleration? It moves with an acceleration of $(F-F_{s,\text{max}})/m$? So what happens to kinetic friction? Should we subtract the result of static friction with $F$ from kinetic friction? Well, we cannot say that F must only counteract $F_{s,\text{max}}$ to move because when $F_{s,\text{max}}$ decreases from $F$, now we have $F_k$ that prevents movement. So in order for an object to move, it must counteract $F_{s,\text{max}}+F_k$ to be able to move, but this does not seem logical. So how will the calculation be?
Isumi
You have so many different $F$ in your question that it is confusing to read for such a simple question.
Your $F_{s,\text{max}}$ should be replaced by $\mu_s N$ and $F_k$ should be replaced by $\mu_kN$, as are standard notation. The relationship then is given by $0<\mu_k<\mu_s$ and that succinctly covers everything.
Now because the maximum value of static friction is $\mu_sN$, this means that whenever $F\leqslant\mu_sN$ the object does not move at all.
However, once the object moves, the acceleration is clearly $a=\dfrac{F-\mu_kN}m=\dfrac{F-F_k}m$ and static friction completely disappears from any moving scenario, as the name ``static" requires it to! Your thing about $F_{s,\text{max}}+F_k$ is just silly.
Since the kinetic friction force is generally less than the limiting static friction force, because $\mu_{k}\lt \mu_s$, if the applied force is maintained at the level that caused motion to start (equal to the max static friction force), the net force will be $\mu_{s}N-\mu_{k}N$, where the term $\mu_{s}N$ is the applied force, not the static friction force which ceases once motion starts. The acceleration $a$ will be
$$a=\frac{(\mu_{s}N-\mu_{k}N)}{m}$$
Hope this helps.
Bob D
  • 81,786
2nd Law of Newton still applies. Get the net loading (sum of the loads with proper signs) and use it to calculate the acceleration.
So you have an applied force $F_a$ and some frictional force $F_f$ on the contact surface.
Newtons 2nd law states that $$F_a - F_f = m a \tag{1}$$
but the above is not sufficient to solve the problem as both $a$ and $F_f$ are not known.
You need an assumption
  • Assume sticking, if the body are assumed to be stuck to the ground then $a=0$ is to find that $$F_a - F_f = 0 \tag{2}$$ and thus $F_f = F_a$
  • If $F_f > F_{\rm s,max}$ then the above assumption cannot be true and now you have to assume slipping. Here $F_f = F_{\rm s,max}$ and thus $$ F_a - F_{\rm s,max} = m a \tag{3}$$ and thus $a = \frac{F_a - F_{\rm s,max}}{m}$
jalex
  • 3,765
