I primarily want to understand what does GR (or any other theory) being scale invariant actually mean. In GR, in vacuum, the theory is scale invariant because there are no fundamental dimensionful constants i.e. the equation simply is $R_{\mu \nu} = 0$.
I read that it is the constant in the theory (like $G$ in gravity, $c$ in SR, etc) that sets the 'scale' of the measurables in the theory. So I don't understand how do they set an inherent scale and also what exactly does it mean that GR is scale invariant.
Consider the QED action:
$$ S = \int d^4x \, \left[ - \frac{1}{4}F^{\mu\nu}F_{\mu\nu} + \bar\psi(i\gamma^\mu\partial_\mu - m)\psi + ej^\mu A_\mu \right] $$
We need the action to be dimensionless, and $d^4x$ has dimension $-4$ (i.e. $[d^4x] = -4$). Thus, the terms in the Lagrangian density must have mass dimension $4$. Expanding the electromagnetic tensor as $F^{\mu\nu} = \partial_\mu A_\nu - \partial_\nu A_\mu$ and $[\partial] = 1$, we see that $[F^{\mu\nu} F_{\mu\nu}] = 2[\partial] + 2[A_\mu] = 4$ implies that $[A_\mu] = 1$. Doing the same exercise for the term with the spinor field and derivative, we find $[\psi] = 3/2$. Then, from $[\bar\psi m \psi] = 2[\psi] + [m] = 4$, we get $[m] = 1$. Therefore, $m$ has mass dimension $1$ (thus, we call it the mass term). Finally, since $j^\mu = \bar\psi\gamma^\mu\psi$, we get $[e] = 0$.
Therefore, this theory has a dimensionless parameter $e$ and a dimensionful parameter $m$. Now, under the renormalization group (RG), the fact that $m$ has dimension $1$ and $[m] = 1 < 4 = d$ means that the coupling is relevant, i.e., it grows in the low-energy regime. Thus, at low-energies, particles become more massive and non-relativistic, while at high-energies they become massless and relativistic. Since $[e] = 0$, this coupling is marginal under RG, meaning that we need to compute its beta function to understand how it behaves at different energy scales. At one loop order, we have $$ \beta(e) = \frac{e³}{12\pi^2} $$ Which means that $e$ increases with the energy scale, introducing another scale dependence to the theory.
epelaez
  • 161
