10
The question is about P&S QFT Problem 6.3. In question (a), the contribution to $a = \frac{g - 2}{2}$ from Higgs boson is calculated, the result is:
$$ \delta a = \frac{\lambda^2}{16 \pi^2} \int_0^1 \mathrm{d} x \frac{(1-x)^2(1+x)}{(1-x)^2 + x (m_h/m)^2}. $$
We want to evaluate the integral in the limit $\frac{m_h}{m} \gg 1$. My strategy is to divide the integral region into two part.
For $x \in [(m_h/m)^{-2},1]$, the denominator is dominated by the second term, approximate: $$ \int_{(m_h/m)^{-2}}^1 \mathrm{d} x \frac{(1-x)^2(1+x)}{(1-x)^2 + x (m_h/m)^2} \approx \int_{(m_h/m)^{-2}}^1 \mathrm{d} x \frac{(1-x)^2(1+x)}{x (m_h/m)^2} = (m_h/m)^{-2} \left[2 \log(\frac{m_h}{m}) - 1 + \mathcal{O}((m_h/m)^{-2})\right]. $$
For $x \in [0, (m_h/m)^{-2}]$, the denominator is dominated by the first term, approximate: $$ \int_{0}^{(m_h/m)^{-2}} \mathrm{d} x \frac{(1-x)^2(1+x)}{(1-x)^2 + x (m_h/m)^2} \approx \int_{0}^{(m_h/m)^{-2}} \mathrm{d} x (1+x) = (m_h/m)^{-2}[1 + \mathcal{O}((m_h/m)^{-2})]. $$
So we get the approximate result(an over estimation): $$ \int_0^1 \mathrm{d} x \frac{(1-x)^2(1+x)}{(1-x)^2 + x (m_h/m)^2} \approx 2 (m_h/m)^{-2} \log(\frac{m_h}{m}).\tag{1} $$
However, in the solution of Zhong-Zhi Xianyu, he used the approximation: $$ \int_0^1 \mathrm{d} x \frac{(1-x)^2(1+x)}{(1-x)^2 + x (m_h/m)^2} \approx \int_0^1 \mathrm{d} x \left[\frac{1}{1 + x(m_h/m)^2} - \frac{1 + x - x^2}{(m_h/m)^2}\right] = (m_h/m)^{-2}\left[2 \log(\frac{m_h}{m}) - \frac{7}{6}\right] .\tag{2} $$
These approximations are asymptotically identical, but, for question (b), plugging in $m_h \approx 60$GeV, the exact result is $1.608817386\times 10^{-9}$, my approximation gives $1.69344 \times 10^{-9}$, a high relative error, while equation (2) gives $1.608817573 \times 10^{-9}$, almost exact.
My question is, what's the idea behind approximation (2), and for integral similar to this, are there some systematic methods to get a good approximations for some parameter $\gg 1$
In your approximation, the denominator is not always dominated by the first term when $x<(m_h/m)^{-2}$ or by the second term when $x>(m_h/m)^{-2}$. Indeed, when $x=(m_h/m)^{-2}$, the first and the second term are roughly equal in the limit $m_h\gg m$. Of course, you could hope that the region around $x=(m_h/m)^{-2}$ isn't very important compared to the rest of the integral.
The approximation in Zhong-Zhi Xianyu's method comes from writing the integrand as $$\frac{(1-x)^2(1+x)}{(1-x)^2+x(m_h/m)^2} = \frac{1-x-x^2+x^3}{1-2x+x^2+x(m_h/m)^2}$$ In the denominator, we can't necessarily ignore the $1$ term compared with $x(m_hm)^2$ because $x$ can be small. However, we can ignore the terms $-2x+x^2$ compared to $x(m_h/m)^2$. This leaves us with $$\frac{1-x-x^2+x^3}{1+x(m_h/m)^2} = \frac{1}{1+x(m_h/m)^2} - \frac{x+x^2-x^3}{1+x(m_h/m)^2}$$ $$= \frac{1}{1+x(m_h/m)^2} - \frac{1+x-x^2}{1/x+(m_h/m)^2}.$$ When $1/x$ is comparable to $(m_h/m)^2$, the second term is very suppressed compared to the first term, while for $1/x\ll (m_h/m)^2$, we can drop this term in the denominator leaving just $$\frac{1}{1+x(m_h/m)^2} - \frac{1+x-x^2}{(m_h/m)^2}.$$
Observe the form of the integration closely and you will find that this integration can be done analytically.
$$ \int_0^1 dx\, \frac{(1 - x)^2 (1 + x)}{(1 - x)^2 + x \left( \frac{m_h}{m} \right)^2}= \int_0^1 dx\, \frac{x^3-x^2-x+1}{x^2-tx+1} $$
here we take $t=2-(\frac{m_h}{m})^2$ for simplification.
Simplifying it further we have
$$\int_0^1 dx\, \frac{x^3-x^2-x+1}{x^2-tx+1}=\int_0^1 dx\,[x+t-1+\frac{(t^2-t-2)x-(t-2)}{(x-\frac{t}{2})^2+(1-\frac{t^2}{4})}]$$
To simplify the calculation further we take $$p=\frac{t-2}{t^2-t-2}$$ and the equation becomes: $$\int_0^1 dx\,[x+t-1+(t^2-t-2)\frac{x-p}{(x-\frac{t}{2})^2+(1-\frac{t^2}{4})}]=\int_0^1 dx\,(x+t-1)+(t^2-t-2)\int_0^1 dx\,\frac{x-p}{(x-\frac{t}{2})^2+(1-\frac{t^2}{4})}$$
the first integral can be evaluated easily
$$\int_0^1 dx\,(x+t-1)=t-\frac{1}{2}$$
the second integral takes a little more effort
$$(t^2-t-2)\int_0^1 dx\,\frac{x-p}{(x-\frac{t}{2})^2+(1-\frac{t^2}{4})}=(t^2-t-2)\int_0^1 dx\,\frac{x-\frac{t}{2}+(\frac{t}{2}-p)}{(x-\frac{t}{2})^2+(1-\frac{t^2}{4})}= \int_0^1 \frac{x-\frac{t}{2}}{(x-\frac{t}{2})^2+(1-\frac{t^2}{4})}dx+ \int_0^1 \frac{\frac{t}{2}-p}{(x-\frac{t}{2})^2+(1-\frac{t^2}{4})}dx $$
Both of the integral can be evaluated easily $$\int_0^1 \frac{x-\frac{t}{2}}{(x-\frac{t}{2})^2+(1-\frac{t^2}{4})}dx=\frac{1}{2}\int_0^1 \frac{x-\frac{t}{2}}{(x-\frac{t}{2})^2+(1-\frac{t^2}{4})}d(x-\frac{t}{2})^2=\frac{1}{2}\int_0^1 \frac{x-\frac{t}{2}}{(x-\frac{t}{2})^2+(1-\frac{t^2}{4})}d[(x-\frac{t}{2})^2+(1-\frac{t^2}{4})]=\frac{1}{2} \left. ln[(x-\frac{t}{2})^2+(1-\frac{t^2}{4})]\right |_0^1=\frac{1}{2} ln(2-t)$$
and
$$\int_0^1 \frac{\frac{t}{2}-p}{(x-\frac{t}{2})^2+(1-\frac{t^2}{4})}dx=(\frac{t}{2}-p)\frac{1}{\sqrt{1-\frac{t^2}{4}}}\int_0^1 \frac{1}{[\frac{1}{\sqrt{1-\frac{t^2}{4}}}(x-\frac{t}{2})]^2+1} d[\sqrt{1-\frac{t^2}{4}} (x-\frac{t}{2})]=(\frac{t}{2}-p)\frac{1}{\sqrt{1-\frac{t^2}{4}}} \left. arctan(\frac{x-\frac{t}{2}}{\sqrt{1-\frac{t^2}{4}}})\right |_0^1$$
so the final result is (calculated totally by hand)
$$t-\frac{1}{2}+(t^2-t-2)[\frac{1}{2} ln(2-t)+(\frac{t}{2}-p)\frac{1}{\sqrt{1-\frac{t^2}{4}}} \left. arctan(\frac{x-\frac{t}{2}}{\sqrt{1-\frac{t^2}{4}}})\right |_0^1]$$ with $t=2-(\frac{m_h}{m})^2$ and $p=\frac{t-2}{t^2-t-2}$
you can simplify it further by substituting $t=2-(\frac{m_h}{m})^2$ and $p=\frac{t-2}{t^2-t-2}=\frac{1}{t+1}$ into the equation and if $m_h$ and $m$ is given it shouldn't be hard even to evaluate it by hand (except for the arctan part). if you make further approximation on arctan, like doing an Taylor expansion, it is possible that you can directly make an approximation solely by hand, without using Mathematica.
My idea is that if the approximation does not come to your mind immediately, it is better to use the general way. although it is tedious, it can be applied to most of the case.Because if you are stuck with finding an approximation, you might even spend more time than direct evaluation.
Interstellar
  • 1,593
I'll write your integral as $$ I = \int_0^1 dx \frac{(1-x)^2(1+x)}{(1-x)^2+x/\epsilon^2} , \qquad \epsilon = \frac{m}{m_h} \ll 1. $$ Change integration variable to $x \to \epsilon^2 x$. Then, $$ I = \epsilon^2 \int_0^{1/\epsilon^2} dx \frac{(1-\epsilon^2 x)^2(1+\epsilon^2x)}{(1-\epsilon^2x)^2+x} $$ We can now perform the approximation by expanding the integrand in powers of $\epsilon$ and then performing the integral. Depending on the power $n$ of $\epsilon$ where I decide to stop the Taylor expansion, I get a good or a bad approximation.
In particular, if I stop at $n=0$, then $$ I \approx \epsilon^2 \int_0^{1/\epsilon^2} dx \frac{1}{1+x} = \epsilon^2 \ln(1+1/\epsilon^2) = -2 \epsilon^2 \ln \epsilon + O(\epsilon^4) $$ This is the result you are finding with your calculation.
If go to $n=2$, then \begin{align} I &\approx \epsilon^2 \int_0^{1/\epsilon^2} dx \left[ \frac{1}{x+1}-\frac{(x-1) x \epsilon ^2}{(x+1)^2} \right] \\ &= \frac{\epsilon^2(3 \epsilon ^2+1)}{\epsilon^2+1} [(1+\epsilon ^2+1) \log (1+1/\epsilon^2)-1] \\ &= \epsilon^2 ( - 2 \ln \epsilon - 1 ) + O(\epsilon^4) \end{align} This is a better approximation that's closer to Zhong-Zhi Xianyu's result, but it's not quite there yet. If we go to $n=4$, we find $$ I \approx \epsilon^2 \left( - 2 \ln \epsilon - \frac{3}{2} \right) + O(\epsilon^4) $$ Finally, at $n=6$, we find $$ I \approx \epsilon^2 \left( - 2 \ln \epsilon - \frac{7}{6} \right) + O(\epsilon^4) . \tag{1} $$ This matches Zhong-Zhi Xianyu's result.
Let's go one step further. At $n=8$, we find $$ I \approx \epsilon^2 \left( - 2 \ln \epsilon - \frac{7}{6} \right) + O(\epsilon^4) $$ Thus, we see that the $n=8$ approximation is the same as the $n=6$ approximation at this order in $\epsilon$. You can convince yourself that any higher terms in the Taylor expansion only corrects $I$ at higher orders in $\epsilon$.
Thus, (1) is the correct approximation to $O(\epsilon^2)$. We can go further of course. Doing the Taylor expansion to $n=16$, we find the approximation \begin{align} I &= \epsilon^2 \left(-2 \ln \epsilon - \frac{7}{6} \right) + \epsilon^4 \left(-6 \ln \epsilon -\frac{13}{4} \right) \\ &\qquad \qquad \qquad \qquad + \epsilon^6 \left( - 18 \ln \epsilon - \frac{201}{20}\right) +O (\epsilon^8 ) \end{align} You can verify that this approximation matches the exact result obtained by @interstellar.
Prahar
  • 29,157
Hints:
  1. Let $\epsilon:=\left(\frac{m}{m_h}\right)^2\ll 1$. Then OP's integral becomes $$ I(\epsilon)~:=~\int_0^1\!dx\frac{(1-x)^2(1+x)}{(1-x)^2+\epsilon^{-1}x}.\tag{1}$$
  2. The denominator $$(1-x)^2+\epsilon^{-1}x~=~x^2+(\epsilon^{-1}-2)x+1\tag{2}$$ of OP's integral (1) has a zero for $$x~=~ 1-\frac{1}{2\epsilon} + \sqrt{(\frac{1}{2\epsilon}-1)^2-1}~\approx~ -\epsilon\tag{3}$$ close to zero. It thus make sense to compare OP's integral (1) with the integral $$ J(\epsilon)~:=~\int_0^1\!~\frac{dx}{1+\epsilon^{-1}x}~=~\epsilon\ln(1+\epsilon^{-1})~\approx~ -\epsilon\ln \epsilon,\tag{4} $$ cf. the solution of Zhong-Zhi Xianyu.
  3. In anticipation of the result, let us also divide OP's integral with an overall factor of $\epsilon$. We can now expand the new integrand in a power series in $\epsilon$, cf. Wolfram Alpha. Unfortunately, the new integrand is not integrable at each order of $\epsilon$; however the leading order is integrable:
$$\begin{align}\lim_{\epsilon\to 0}\frac{I(\epsilon)-J(\epsilon)}{\epsilon} ~\stackrel{(1)+(4)}{=}~&\lim_{\epsilon\to 0}\int_0^1dx\left(\frac{(1-x)^2(1+x)}{\epsilon(1-x)^2+x}-\frac{1}{\epsilon+x}\right)\cr ~=~~~&\int_0^1dx\left(x^2-x-1\right)~=~-\frac{7}{6}. \tag{5}\end{align}$$
