I'm working through Goldstein's Classical Mechanics, 3rd edition. In section 2.4, we are extending Hamilton's Principle to a system with constraints. In the beginning of the section he makes a couple statements that I am trying to understand formally.
Passage One
First, in section 2.3, he introduces the notation of $$\delta y_i = \left(\frac{\partial y_i}{\partial \alpha}\right)_0d\alpha.$$ I understand this to be the infinitesimal variation of the curve $y_i(x)$. Thus, $\delta y_i$ is thought of as an infinitesimally small function of $x$. Using the definition $y_i(x,\alpha) = y_i(x,0) + \alpha\eta_i(x)$, we get the identity $\delta y_i = \eta_i(x) d\alpha$ for an arbitrary $\eta_i(x)$ vanishing at the endpoints. In this section, they state that because each $y$ is independent (we are not assuming any constraints) the variations $\delta y_i$ are independent. This allows us to apply the fundamental lemma of variational calculus to go from $$ \int_1^2\sum_i \left(\frac{\partial f}{\partial y_i}-\frac{d}{dx}\frac{\partial f}{\partial \dot{y}_i}\right)\delta y_i dx = 0\tag{2.17} $$ to $$ \frac{\partial f}{\partial y_i}-\frac{d}{dx}\frac{\partial f}{\partial \dot{y}_i} = 0\tag{2.18} $$ for each $i$.
Now in section 2.4 we work with holonomic constraints and use generalized coordinates $q_i$. The first statement I do not know the meaning of is the following
First consider holonomic constraints. When we derive Lagrange's equations from either Hamilton's or d'Alembert's principle, the holonomic constraints appear in the last step when variations in the $q_i$ were considered independent of each other. However, the virtual displacements in the $\delta q_I$'s may not be consistent with the constraints.
(I think $\delta q_I$ might be a typo for $\delta q_i$, but that is what is in my text). Why are $\delta q_i$ not consistent with the constraints? At first I thought that this is because $\delta q_i$ is an arbitrary variation $\eta_i(t)d\alpha$; the violation of constraint comes from the fact that $\eta_i(t)$ can be arbitrary. But that intuition doesn't follow formally: at any time $t$, $q_i$ can be infinitesimally varied and still remain consistent with the constraints by definition. The domain of $q_i$ is $\mathbb{R}$.
Passage Two
The second statement I do not know the meaning of is the following.
We modify the integral in Eq. (2.19) to be $$I=\int_1^2\left(L + \sum_{\alpha=1}^m \lambda_\alpha f_\alpha\right)dt,\tag{2.20}$$ and allow the $q_\alpha$ and the $\lambda_\alpha$ to vary independently to obtain $n+m$ equations. The variations of the $\lambda_\alpha$'s give the $m$ constraint equations. The variation of the $q_i$'s give $$\delta I = \int_1^2 dt\left( \sum_{i=1}^n\left(\frac{d}{dt}\frac{\partial L}{\partial \dot{q}_i} - \frac{\partial L}{\partial q_i} + \sum_{\alpha=1}^m \lambda_\alpha \frac{\partial f_\alpha}{\partial q_i}\right) \delta q_i \right) = 0.\tag{2.21}$$ However, the $\delta q_i$'s are not independent. We choose the $\lambda_\alpha$'s so that $m$ of the equations are satisfied for arbitrary $\delta q_i$, and then choose the variations of the $\delta q_i$ in th remaining $n-m$ equations independently.
Why are the $\delta q_i$ not independent? It was mentioned in the previous sections that each $\delta y_i$ are independent because each $y$ are independent. And by definition $q_i$ are independent from each other because they come from holonomic constraints. Lastly, what is it meant to choose $\lambda_\alpha$'s so $m$ equations are satisfied by arbitrary $\delta q_i$ and then vary the remaining $\delta q_i$? If they are independent, we cannot vary them arbitrarily to invoke the fundamental lemma. Furthermore, for any distinct fixed $\delta q_i$, the set of $\lambda_\alpha$ should also be distinct, correct?
BENG
  • 119
The main logic is as follows:
  1. Around eq. (1.38) Ref. 1 is defining $n=3N-k$ generalized coordinates $(q^1,\ldots, q^n)$ via $k$ implicit holonomic constraints.
  2. In section 2.4 Ref. 1 is including $m$ additional explicit constraints $f_{\alpha}=0$. Therefore the generalized coordinates $(q^1,\ldots, q^n)$ are no longer independent, cf. OP's question.
References:
  1. H. Goldstein, Classical Mechanics, 3rd ed; section 2.4. NB: Be aware that the attempt in Ref. 1 to construct a variational formulation for non-holonomic constraints is flawed and has been retracted, cf. this Phys.SE post.
I'm gonna answer it myself, but after doing a lot of research, it seems that this is very well criticized passage for not being clear enough at all. Here is my perception of what it is trying to communicate.
We are given a monogenic problem with holonomic constraints. The existence of these holonomic constraints imply that the configuration space of the system is not all of $\mathbb{R}^m$, it is in fact a lower dimensional manifold embedded in $\mathbb{R}^m$; while differential geometry is a little out of the scope of Goldstein 2.4, its pretty crucial to the definition. Now for any curve, starting at configuration $\mathbf{x_0}$ in configuration space, the integral $$ I=\int_0^t L(\mathbf{x},\mathbf{x}',t)dt $$
is well defined. Furthermore, the definition of a stationary curve on this manifold is also well defined; note that as curves "shrink" towards the stationary curve as $\alpha\rightarrow 0$, it is not linear, each curve perturbed curve must be on the manifold. This means that we cannot simply have $\mathbf{r(t,\alpha) = \mathbf{r(t)} + \alpha\boldsymbol{\eta}}(t)$. For example if the manifold is a sphere and $\mathbf{r}$ is a line on the sphere, if we have a linear perturbation just mentioned above, the curve will morph to be inside the sphere which violates the constraints.
However, if our holonomic constraints are "nice", we can find generalized coordinates that parameterize the manifold, in this case the linear perturbations will be valid because every curve parameterized by the generalized coordinates is on the manifold. And thus we get the Euler-Lagrange equations, showing that stationary values of $I$ actually follow the path of motion.
Now, this is where the confusion is, and where I think Goldstein is not clear. What if we want to use different coordinates that do not parameterize the manifold? The space parameterized by these new coordinates must contain the valid configurations as a submanifold. We cannot find the stationary values using the normal method of variational calculus because we cannot vary each coordinate arbitrarily and still stay in the manifold of valid configurations. So, we solve a different problem: ignore the constraints and let each coordinate vary arbitrarily and add new variables $\lambda_\alpha$. Now consider the modified integral $$ J = \int_0^t \left(L(\mathbf{q},\mathbf{q}',t) + \sum \lambda_\alpha f_\alpha \right)dt. $$ Now, we use variational calculus to find a stationary curve through this new space in which each $q_k$ varries in all of $\mathbb{R}$. It is left to show that this curve (1) is also in the manifold of valid configurations, i.e. it satisfies the constraints and (2) it is also a stationary curve in the manifold of valid configurations.
(1) follows from the fact that the Euler-Lagrange equations for the variables $\lambda_\alpha$ are simply $f_\alpha(\mathbf{q}) = 0$, and so the stationary curve $(\dots,q_k(t),\dots,\lambda_\alpha(t),\dots)$ has components $q_k$ on the constrained manifold. In other words, for the curve $\mathbf{q}$ we have that $I = J$ ($I$ is defined in both the manifold and all of $\mathbb{R}^n$, while $J$ is only defined in the latter).
(2) follows from the fact that any variation of the curve $\mathbf{q}$ in the constrained manifold is also a variation in all of $\mathbb{R}^n$. And we are done.
What advantage does this serve? Well, the integral $I$ is invariant to which coordinates we use to parameterize the constrained manifold, while the Lagrange equations that we derived from D'Alembert's Principle must always satisfy the constraints. We have used D'Alembert's Principle to show that stationary values of $I$ do in fact have the path of motion. Now knowing this, we can then calculate the stationary value of $I$ without requiring coordinates that satisfy the constraints (by using Lagrange multipliers).
BENG
  • 119
